Advice on fitment of a muffler that i bought
MasterZ
Postby MasterZ » Sat Dec 08, 2007 10:58 am
Hello everyone,
I bought a muffler and im wondering on how to fit it on my NA MX
heres the details on what i bought:
How does it work?
Varex muffler combines both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary between the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance. Whilst for lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort. Also, you are able to control the angle of the valve which can be adjusted to stop at any point between the sports mode and the silence mode. This gives you further freedom to set the optimal sound level according to your preference.
XForce VAREX
Cannon VAREX:
Inlet size: 2.5
Barrel size: 7” O.D, 14” Long
Tip size:4.5” O.D single wall tip
Closed
Open
Remote for muffler
Sorry about a lot of writing
Here are my questions
Has anyone got a cannon style muffler on their mx5?
Will the muffler work, as in fit?
Do I have to get the muffler place to place it on an angle?
Would I have to cut a bit of the rear bumper to make it fit?
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
RaYmO
Postby RaYmO » Sat Dec 08, 2007 11:07 am
Ask Kula, he's got a Varex installed in his NA6
AJ
Postby AJ » Sat Dec 08, 2007 1:39 pm
a remote control exhaust note??? :shock: ..........................sufferin' arseholes.............i've seen it ALL now....ROFLMFAO :lol: :lol: :lol:
i can die a happy man :mrgreen:
XMX5 Rogues
Tezzax5
Postby Tezzax5 » Sat Dec 08, 2007 2:32 pm
AJ the most common use for these type mufflers are drag racing...
Old days turn up to race and drop your rear pipes
Currently you turn up and either manually or auto turn a lever and have a straight thru system...works really well on V8's 8)
Next few years all you will need is an electric car and a voltmeter.... :shock:
AJ
Postby AJ » Sat Dec 08, 2007 2:59 pm
yeah, i knew about the manual changeover tez, had one on my Monaro & then my coon :wink: :mrgreen:
XMX5 Rogues
bensale
Postby bensale » Sun Dec 09, 2007 11:50 am
Isn't that something... Interesting and clever idea. Was it expensive?
www.othersideproductions.com
MasterZ
Postby MasterZ » Sun Dec 09, 2007 1:01 pm
bensale wrote:Isn't that something... Interesting and clever idea. Was it expensive?
I payed $369 for it of eBay with free shipping from this store
http://stores.ebay.com.au/R-Sense-Tuning-Parts
metris
Postby metris » Mon Dec 10, 2007 1:45 pm
I am also interested in how it would fit! (Ive got an NB tho...)
Aaaaanyone??
hey MasterZ are ya gona get the round or oval one?
I wana get one too! :mrgreen:
NA6 turbo cute scary fun machine!! :D
kula
Postby kula » Mon Dec 10, 2007 3:45 pm
i dont have a varex muffler on my car.
i still have the stock system!
we did test one on a forester XT.
it will fit, same place as OEM muffler, i dont think youd have to cut anything.
should be easy.
metris
Postby metris » Mon Dec 10, 2007 3:50 pm
thanks heaps kula,
would it fit in the original muffler position parallel to the bumper? how would you get it to right angle bend and come out the back?
how did it shape up on the forester? what it quiet when closed? ...etc?
bensale
Postby bensale » Mon Dec 10, 2007 5:29 pm
Thanks for that MasterZ.
Its a good idea, I'll be interested to see how it installs and to hear what it sounds like when its in. I guess i'ld just be worried that it would sound like a mutant sheep when its completely open....
If it sounds good and gives good performance (ie: not worse than stock) I'ld be interested in one..
The install would be a bit tricky due to the stock muffler being a completely different shape wouldn't it? But i'm sure an exaust shop would be able to mount it fairlly easily, there seems to be space.
Ben,
MasterZ
Postby MasterZ » Mon Dec 10, 2007 6:35 pm
metris wrote:I am also interested in how it would fit! (Ive got an NB tho...)
Aaaaanyone??
I got the round one, it arrived today too
here are some pics of what was in the box:
Sorry about the large images
MXkal
Postby MXkal » Mon Dec 10, 2007 10:43 pm
I just want to see what a 4.5 inch tip looks like out the back of an NA heh
Overkill is an understatement.
MasterZ
Postby MasterZ » Tue Dec 11, 2007 9:12 am
MXkal wrote:I just want to see what a 4.5 inch tip looks like out the back of an NA heh
I havent installed mine yet but maybe something like this one?
http://www.youtube.com/watch?v=pvpQs35g-t0
kula
Postby kula » Tue Dec 11, 2007 3:00 pm
youll need a angle bend made up for the exit... but any shop can do that.
close up it was perfectly drivable, and quieter than stock!!!
open, it was almost as loud as a straight through 3 inch canon muffler, but a tiny bit less.
