Transmission oil change. Incomplete ... (now complete :P)
Steampunk
Postby Steampunk » Mon Dec 10, 2007 8:58 am
I drained a little bit of the tranny oil in hopes that I can top-up with some anti-friction/seal preservation additive. Unforunately, the dang refill bolt is too tight.
I have drained approx 600ml of transmission oil. Is this ok? I know the capacity is only 2L.
How much of the gearbox internals sit permanently in oil?
Garry
Postby Garry » Mon Dec 10, 2007 10:45 am
Lesson to be learned here grasshopper...........always remove the fill bolt before removing the drain bolt
Steampunk
Postby Steampunk » Mon Dec 10, 2007 2:05 pm
you are wise Obi-Wan.
I'm gonna remove the speedo cable thingy and fill it up from there.
Steampunk
Postby Steampunk » Mon Dec 10, 2007 9:09 pm
Speedo cable was not where I thought it was, so I managed to top up the gearbox via the reverse light switch.
[Grasshopper takes stone from master's hand]
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Mon Dec 10, 2007 11:10 pm
Are you certain you didn't over fill it young padawan???
Postby bruce » Tue Dec 11, 2007 11:11 am
It almosts sounds funny - I filled up my tranny fluid by topping up the radiator reservoir !
sabretooth
Postby sabretooth » Tue Dec 11, 2007 11:28 am
Yeah, so how do you know you didn't overfill it? Or did you only put 600ml of that additive back in again?
Steampunk
Postby Steampunk » Tue Dec 11, 2007 12:45 pm
Yup, I measured how much I took out, and put back in what I lost.
Went and bought those seringe thingys.
