Where to buy Cam Cover Gasket? (Brisbane)
Posted: Fri Jan 11, 2008 10:21 pm
by TieNN89
Does anyone know where to go to get a new Cam Cover Gasket?
I'm hoping to replace it this Sunday
I started noticing when I accelerate that it wasn't smooth so first thing i checked was the spark plugs
and the spark plugs happen to have oil over it (was recently replaced 2000k ago)
so my guess is the gasket needs replacing
I know Mania sells them except there in Sydney
http://www.mx5mania.com/product958.htm
Posted: Fri Jan 11, 2008 10:31 pm
by Uncle Arthur
I really hate to be first to state the bleedingly obvious here....... and I don't mean to seem unreasoably harsh............
Have you tried a Mazda dealership?
http://www.mazda.com.au/Repco?
www.repco.com.auSupercheap?
www.supercheapauto.com.au
Posted: Fri Jan 11, 2008 10:35 pm
by TieNN89
Supercheap Repco Autobarn checked them they all require ordering
I haven't tried Mazda yet tho
Question could it be the bolts aren't tight
cause there was a leak on the side near the exhaust ... and dad tightened up the bolts around there and it has stopped leaking
Its only the spark plug up the front no1 i think it is that has oil the others are dry
should i just replace it now that its leaking or is it safe to try tightening up the bolts a bit
Posted: Fri Jan 11, 2008 11:20 pm
by SuperMazdaKart
i'd make sure to get the Camshaft Angle Sensor seal too while at it. No better time to replace that one then together with the rocker cover gasket.
Posted: Sat Jan 12, 2008 10:28 am
by john!
Spend the extra and get the genuine one, the aftermarket ones do tend to not hold up as well from all reports.
Just remember to look at the articles on miata.net
http://www.miata.net/garage/valvecover/index.html on adding gasket goo to the corners, and to tighten the bolts in the correct sequence and to the correct torque.
hope this helps
john!
Posted: Sat Jan 12, 2008 12:18 pm
by TieNN89
thanks everyone
i think i found the problem
i just tighten them up a bit so hopefully it shouldn't leak no more
Posted: Sat Jan 12, 2008 1:58 pm
by Steampunk
When it comes to changing seals and gaskets on a car that seems to never have had it done, then you may as well change the whole lot in one go instead of just doing one.
Do some reasearch and find all the part numbers you need for rocker-cover, cam-angle sensor etc., so you will be ready.
And I would go for genuine Mazda OEM parts cause it's not that much more expensive than aftermarket, will fit perfectly, and will last you for 100,000kms+.
Posted: Sun Jan 20, 2008 1:16 pm
by TieNN89
Posted: Sun Jan 20, 2008 1:59 pm
by Steampunk
yup
Posted: Sun Jan 20, 2008 3:24 pm
by TieNN89
awesome
is it hard to change that one
as far as i know to change the cam cover one its just a matter of removing the bolts on the cover and remove the old gasket put the new one in a bit of silicon here and there and then the cover can go on
also while i'm in there anything else i should change as well
Posted: Sun Jan 20, 2008 3:45 pm
by JBT
SuperMazdaKart wrote:i'd make sure to get the Camshaft Angle Sensor seal too while at it.
AZNTien has an NB. No CAS.
Time to update that signature block Tien re QM Falls
Posted: Sun Jan 20, 2008 5:28 pm
by TieNN89
JBT wrote:SuperMazdaKart wrote:i'd make sure to get the Camshaft Angle Sensor seal too while at it.
oh i don't have a CAS so just the cam cover will do i guess
now i just need to wait for that plastic to arrive which is taking a lot of time
hehe thanks for that
forgot about my sig
