AFR's who's running what
- 16bit
I am really interested to see what afr's people are running - in particular forced cars. I am running 12.5 atm but it could apparently go leaner.
- Steampunk
On the dyno day last saturday that you piked on
, the Mazda3MPS'ses and a Holden Astra HSV VX-R were showing up between 12.5 to and 11.5 on average.
The VX-R got all the way down to 10 nearing redline.
I think all of them had standard EMS tuning, and the power @ wheels they were making match their claimed power at the flywheel.
Why would you go leaner? The most powerful 3MPS (152kw@wheels) had the richest mixture out of the lot.
- 16bit
As some of you know I'm running a FM/Link ECU. I'm using the AFR targets as set in the FM install manual. These may be adjusted when I finally get her on a dyno.
My current targets are:
140Kpa - AFR=12.5
180Kpa - AFR=11.5
227Kpa - AFR=10.5
The above boost levels are the centres of my ECU pressure tables while under boost. My wastegate currently opens at 160Kpa.
J
140Kpa - AFR=12.5
180Kpa - AFR=11.5
227Kpa - AFR=10.5
J
16bit wrote:how come the internets conversion dooies said that it was 23psi at 160kpa?
Don't know the answer to the question...but I know that when my boost gauge is showing 9 pounds, the ECU display is showing 162Kpa and there is a conversion table in the FM tuning guide that shows 162Kpa as being 9 pounds.
According to the same table 227Kpa is about 18.5 pounds.
J
- Matty
Juffa wrote:16bit wrote:how come the internets conversion dooies said that it was 23psi at 160kpa?
J
absolute vs gauge pressure.
- timk
