Differential pinion gear and crown go crunch
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sat Mar 08, 2008 11:17 pm
Goes crunch.
Car no go.
sabretooth
Postby sabretooth » Sat Mar 08, 2008 11:43 pm
Ouch.
Time for a new driveshaft?
JBT
Postby JBT » Sun Mar 09, 2008 6:40 am
Sorry I could not mount a rescue UA.......too much wine/beer/BBQ which was still in progress. I reckon my BAL was probably about 0.15 :roll:
Breathe easy if it's just a driveshaft CV joint.......much better than a dead diff.
Postby manga_blue » Sun Mar 09, 2008 9:56 am
Congratulations. It takes good power to do that. :D
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Mar 09, 2008 10:01 am
Time for 1.8 diff conversion...
Uncle Arthur
Postby Uncle Arthur » Sun Mar 09, 2008 12:02 pm
JBT wrote:Sorry I could not mount a rescue UA.......too much wine/beer/BBQ which was still in progress. I reckon my BAL was probably about 0.15 :roll:
No probs JBT :D - and it looks like a driveshaft CV joint (well - sounded like it)
Boags
Postby Boags » Sun Mar 09, 2008 12:05 pm
You have been a naughty boy! :twisted:
Don't be too surprised if it's the diff though. :frown:
StanTheMan
Postby StanTheMan » Sun Mar 09, 2008 1:14 pm
are you still running a 1.6 diff :shock:
and if it turns out to be the CV joint :lol: :lol:
Thats not the way its supposed to work
Boags
Re: Blew a rear uni joint
Postby Boags » Sun Mar 09, 2008 1:24 pm
Uncle Arthur wrote:Goes crunch.
Car no go.
So you put it in gear and let out the clutch and wheels don't turn? Unless the drive shaft actually fell out; I think it's diff. :cry: Fecked universals vibrate badly, they don't stop you from going (AFAIK - please correct me if I'm talking sh!t).
Boags
Postby manga_blue » Sun Mar 09, 2008 5:43 pm
Non-LSD diff driving a broken halfshaft would mean you don't go anywhere. All power would go to the broken side which would just turn and grind away.
In any case it's easy enough to check. Just get someone to look at the half-shafts while you try to move off.
StanTheMan
Postby StanTheMan » Sun Mar 09, 2008 6:50 pm
If you've broken a CV joint. Wouldn't it stick out like dogs balls?
You'd have bits of bearing flying everywhere .
My diff made all sorts of grinding noises when it had gone pear shape. but in my case the dead give away was the fact that the dif case was split & the oils was leaking & left a nice tell tale to where i'd rolled to to stop.
Anyway I hope its not the diff......another pretty expensive excersise....but then. mmmmm....more upgrades for UA.
Uncle Arthur
Postby Uncle Arthur » Sun Mar 09, 2008 8:43 pm
Weeeeellllllllll..
It ain't the uni joint. Pinion gear has shattered. Chipped a few teeth on the crown to boot. Mazdaspeed centre is still good.
Will be looking to put the lot up for sale to interested buyers to explore the torsen option. I bought this complete from Cal a while back, had it rebuilt, so I can tell you how much you should expect to pay to have this rebuilt. I needed a new pinion. You are obviously going to need new crown and pinion. I would suggest a full rebuild because of possibility of metal shavings, but the centre is intact - I'll strip it to be sure.
It has held up to well over 110 RWKW for a while now, so would be great for a NA version with a bit of grunt - just don't use the mazda pinion gear - get an aftermarket made up. If you are interested, let me know.
Here's a pic........
JBT
Postby JBT » Sun Mar 09, 2008 9:48 pm
Baaaargar :cry: . MX-5 Plus had a fair stock of TorSens a while back.
MxJadeMonkey
Postby MxJadeMonkey » Sun Mar 09, 2008 10:10 pm
How much for the Mazdaspeed centre please?
1991 NA6 Velocity Blue (Ford Colour)
corners
Vehicle: ND - Supercharged
Postby corners » Mon Mar 10, 2008 8:08 am
Hmm I have done that before.
The inside of your diff doesnt look very clean :?
