Hydra Nenemis installation?
AB7
Postby AB7 » Tue Apr 08, 2008 3:43 pm
Hi Guys,
I'm about to install Hydra nemesis ECU on my NB8B.
The harness is pretty straight forward, and the MAP sensor pick up is from the 'nipple' on top of the intake manifold.
Other than that, is there anything that I should worry about?...Do I need to disconnect the battery for precaution?
Cheers.
Postby Okibi » Tue Apr 08, 2008 3:49 pm
If you bought it from Flyin Miata ask them, Keith is really good with support.
I think Rod is the only other person I know who's done the hydra.
AB7
Postby AB7 » Tue Apr 08, 2008 4:11 pm
Actually its Rod's ex :)
PASHN8
Postby PASHN8 » Wed Apr 09, 2008 12:07 pm
AB7, non-turbo MX-5? Did the Hydra come pre-loaded with the base map, as from my knowledge it is a standalone ECU yes?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
AB7
Postby AB7 » Wed Apr 09, 2008 4:47 pm
Yep mine is non turbo. Hydra is standalone ECU, they can handle SE or SP as well. Quite a lot of people are using it for their Miata MSM in US.
blackster
Postby blackster » Wed Apr 09, 2008 5:13 pm
AB7 wrote:Yep mine is non turbo. Hydra is standalone ECU, they can handle SE or SP as well. Quite a lot of people are using it for their Miata MSM in US.
Yes they are number being used by MSM users, whether they have issues or not is questionable. Has hydra set up shop in aus to offer support? I ask because when i enquired about it there was no local support or intention of it.
Previous
04' MX5 SE.
02' MX5 Classic ed.
maxmx5
parts
Postby maxmx5 » Wed Apr 16, 2008 12:58 am
Hi AB7,
man looks like you are spending a bit of $$ on you 5... good luck with everything...
