does it help them last longer or work better if given the occasional clean?
in maybe degreaser, rinsed & air dried before re-installation.
are O2 sensors cleanable?
- SuperMazdaKart
- Matty
- SuperMazdaKart
- irwin83r
- Matty
SuperMazdaKart wrote:hrm ok thanks. i'm not worried bout any difficulties with changing it, done it twice before already. next one might be a 4 wire just so it starts working straight away on a cold engine though.
I had a 4 wire for a while (died after a year) then went back to a 1 wire (Repco generic). It heated just as fast (verified by AFR meter), and for its purpose was just as accurate.
- Boags
irwin83r wrote:little OT but is there any advantage to running a wide band on a N/A setup?
Only if you have an aftermarket ECU.
- irwin83r
Boags'MX5 wrote:irwin83r wrote:little OT but is there any advantage to running a wide band on a N/A setup?
i do... but its not in the car just yet.. should i get one and install it at the same time as the ECU?
- AB7
irwin83r wrote:Boags'MX5 wrote:irwin83r wrote:little OT but is there any advantage to running a wide band on a N/A setup?
X2
Can someone explain the purpose of running wide band on A/F ECU?
- Boags
Narrow band sensors are accurate over a NARROW BAND of a/f ratios. Specifically; they are acurate around 14.7:1 (stoich). The resolution gets worse the further you are from stoich. A wide band sensor gives you the same resolution over a WIDE BAND of ratios.
I'm sure my terminology is wrong, but you get the idea. The stock ECU can't take the difference, so you can't plug a wide band into your stock ecu. If you have an aftermarket ECU you can use the wideband to tune more accurately. With a turbo, this is a must.
Boags
Boags
- irwin83r
Boags'MX5 wrote:Narrow band sensors are accurate over a NARROW BAND of a/f ratios. Specifically; they are acurate around 14.7:1 (stoich). The resolution gets worse the further you are from stoich. A wide band sensor gives you the same resolution over a WIDE BAND of ratios.
Boags
thanks boags.
so a good idea for a nb8a with cams and ecu?
