hey guys im about to change my diff and gb oil so i have bought the appropriate oils for both my GB and diff only to get under the car to find i have a viscous lsd diff..
well what i was told was a viscous LSD. it has a finned case which is apparently the kicker when visually looking at the differance between it and a standard NA6 diff (standard na6 open diff has a smooth case) correct me if im wrong.
before i change the oil i just want to know if i should return the oil i have got and replace it with LSD oil
can anyone tell me how to confirm which diff i have. the car is a Jap imort NA6 with a finned case cover on the diff.
thanks guys
LSD diff oil for Viscous diff?
- garettb16
- Matty
Re: LSD diff oil for Viscous diff?
garettb16 wrote:well what i was told was a viscous LSD. it has a finned case which is apparently the kicker when visually looking at the differance between it and a standard NA6 diff (standard na6 open diff has a smooth case) correct me if im wrong.
You're wrong.
All diffs were finned after the first few hundred.
Matty wrote:garettb16 wrote:well what i was told was a viscous LSD. it has a finned case which is apparently the kicker when visually looking at the differance between it and a standard NA6 diff (standard na6 open diff has a smooth case) correct me if im wrong.
You're wrong.
bah bow! matty has spoken! do not pass go, do not collecto $200.
- JBT
garettb16 wrote:before i change the oil i just want to know if i should return the oil i have got and replace it with LSD oil
They all use the same (non-LSD) oil.
- JBT
