QLD - Pod Filters
TieNN89
QLD - Pod Filters
Postby TieNN89 » Thu May 08, 2008 12:17 am
Does anyone know if its legal or not to have a pod filter not in a box under the bonnet?
I've been told that it needs to be mounted to the car
and I've been told it needs to be in a box because of fire hazard
Sheck
Postby Sheck » Thu May 08, 2008 12:24 am
as far as i know it just needs a mount holding it.
The queensland transport guys went through my car and only found the BOV needing to be plumbed into the intake. And my pod wasn't even mounted properly
Steampunk
Postby Steampunk » Thu May 08, 2008 9:06 am
and I heard they prefer you to have a heat-shield of some description between the engine and pod
sabretooth
Postby sabretooth » Thu May 08, 2008 11:04 am
Pure hearsay, but my understanding (and is probably wrong) is that if you have an oiled filter it must be enclosed.
Why would they be concerned with heat shields?
Steampunk
Postby Steampunk » Thu May 08, 2008 11:12 am
sabretooth wrote:Why would they be concerned with heat shields?
Dunno, I just heard it from someone... perhaps to minimise fire hazard if it's an oiled one? :roll:
sabretooth
Postby sabretooth » Thu May 08, 2008 11:37 am
Another interpretation of the enclosed thing, I suppose.
TieNN89
Postby TieNN89 » Sat May 10, 2008 9:50 pm
well i got a pod in mine :D its a SAAS brand which I'm pretty sure isn't one of those oil type filters cause it doesn't feel oily
its mounted to the body
has a heat shield and i'm surprise it works
i've got an infrared temp thing and i took a temp reading on the outside of the shield and the inside (where the pod is) and its lower
