Replaced the battery and something strange is happening.
- Steampunk
Ok, first of all allow me to apologise as this does not relate to my MX-5 but my Ford Festiva.
- I replaced my battery with a new one.
- Idled lower than usual, and rather rough
- left it idling for 12 mins then went for a drive
- as soon at the car hit the mid-range, power faded considerably
The only way I can describe the loss of power is it's like I lost a cylinder, or like a complete opposite of \"coming on boost\" in a turbo car.
It would accelerate as per usual up till about 3,500RPM then the power literally plateaus. The engine would still rev as fast as normal, but the car just doesn't accelerate as fast as it should.
Any ideas?
Surely changing the battery wouldn't reprogram the ECU dramatically, would it?
Any ideas?
- Steampunk
- JBT
- ampz
- Vehicle: NA6 - Turbo
Festivas work a little differently to mx5s JBT
I would be checking for any blown fuses (if not already done so) and loose wires near the battery.
You may have unplugged something close by and it is necessary for the car to rev (maybe a vacuum valve or presurre sensor).
I once installed a battery back to front
and blew the fusible link. Then proceeded to swear at everything on the car (and the world) until i realised what i did (i was feeling a little precious that night)...
Huh?
- cshaks
- Vehicle: ND - 2
battery voltage
Hi 1red5,
I would perhaps check the bettery voltage prior to startup. I had a similar problem with a mazda 323 Astina a few years ago. Everything pointed to a dud idle stepper motor, but once I replaced the battery the problem disappeared. We finally figured out that the battery voltage prior to startup was too low to allow the idle stepper to find its true home position and therefore the stepper was not working properly.
Perhaps your new battery is not quite what it should be.
I may be completely wrong here, but its worth checking!
Hope this helps...
Chris
Hope this helps...
Chris
SOLD: '95 NA8 White with custom tan leather. BD bar, King Springs, 15" NB alloys.
Now driving a Mazda6 luxury sports.
- Steampunk
- SuperMazdaKart
- SuperMazdaKart
