bleed order
16bit
Vehicle: NB8A - Supercharged
bleed order
Postby 16bit » Tue Jun 03, 2008 3:25 pm
just wondering what the bleeding order is for an nb8a. thanks!
JBT
Postby JBT » Tue Jun 03, 2008 3:30 pm
Start with the longest brake line from the master cylinder and end with the shortest. Should be something like, LR, RR, LF, RF but depends how the lines were run.
Postby Okibi » Tue Jun 03, 2008 5:55 pm
Yup that sounds correct. I can't confirm til i'm home.
(Right hand drive)
Passenger Rear
Drivers Rear
Passenger Front
Drivers Front
16bit
Postby 16bit » Tue Jun 03, 2008 6:13 pm
sweet thanks!
Woo
Vehicle: 10AE - Turbo
Postby Woo » Thu Jun 05, 2008 7:54 pm
Swap the Left and Rights in the above descriptions accounting for ABS on the '00 (four wheel ABS)
Swap the Front Left and Front Right on the '99 with ABS (3 wheel ABS)
Edit* The key is as JBT says start with the longest line (from the ABS pump or Master cylinder)
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
