1.8 Firing order
Woo
Vehicle: 10AE - Turbo
1.8 Firing order
Postby Woo » Sun Jun 29, 2008 11:54 pm
There seems to be some confusion as to the firing order of the 1.8. Is it the same or different to the 1.6
Some sources say 1-3-4-2 however from my experience most 4 cylinder motors are 1-4-3-2
This is of course determined by the cams the motor has in it.
discuss 8)
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
Postby Okibi » Mon Jun 30, 2008 12:20 am
Woo
Postby Woo » Mon Jun 30, 2008 7:35 am
Ok Okibi, thanks ...... but
as the coils are wasted spark (two cylinders fire at once), for the 1.8, that would read 1 (or 4) - 3 (or 2) - 4 (or 1) - 2 (or 3), so 1-3-4-2
And thats assuming that the coils fire sequencially.
Mazda have a reputation for group firing, being coil 1 twice then coil two twice. That would make the firing order 1-4-3-2.
The big sites link is great for matching plugs to coils on a standard system but doesn't actually show the firing order, see what i'm getting at?
I'm leaning towards 1-3-4-2 and to be sure might read the cams (for that 100% feeling 8) )
JBT
Postby JBT » Mon Jun 30, 2008 11:08 am
Why do you need firing order?
Plug lead layout connection for 1.8 below. Doesn't matter if 1/4 and 2/3 are arranged differently as long as 1/4 are on the right coil pack and 2/3 are on the left coil pack.
Woo
Postby Woo » Mon Jun 30, 2008 11:23 am
Sequencial injector firing JBT
The aftermarket controller fires the injectors according to cylinder timing order.
output 1 fires no 1 cylinder
output 2 fires no 3 cylinder
output 3 fires no 4 cylinder
output 4 fires no 2 cylinder
Thats assuming a firing order of 1-3-4-2
Maybe I should have said engine timing order rather than firing order, sorry but thanks anyway 8)
JBT
Postby JBT » Mon Jun 30, 2008 12:47 pm
Aaah, OK. Yes 1-3-4-2 for the 1.6. I'm not sure of the 1.8 though.
Found this and this.
Woo
Postby Woo » Mon Jun 30, 2008 7:46 pm
Hahaha I had just registered as a poster on the first link JBT, ain't Google a wonderful thing :mrgreen:
By the looks of the 2nd link the timing order is unchanged (both 1-3-4-2) for the 1.6 and 1.8.
Thanks for the help guys, one step closer 8)
