wheres the fuel filter located on bp?
RG.net
Postby RG.net » Mon Jul 21, 2008 6:30 pm
any ideas anyone? i'm on the quest to cure my fuel consumption loss, so far i have changed:
spark plugs (all 4 were fouled serviced 5k ago, how long do they normally last?)
oil fiter (bleck as bleck can be)
castrol EDGE sport 10-60w (great oil but unfortunatly is going straight through my engine, will need a thicker oil)
02 sensor (cured my idle dip but not the fuel consumption)
leads (stockies were on the way out, again helped make the car run smoother)
next on my mind is the fuel filter, as i dont know how long ago it was done. anyone know where abouts they are ?
TieNN89
Postby TieNN89 » Mon Jul 21, 2008 6:32 pm
under the car, drivers side before the rear wheel
its got a plastic black cover over it
RG.net
Postby RG.net » Mon Jul 21, 2008 6:40 pm
AZNTieN wrote:under the car, drivers side before the rear wheel
thanks, anything i should know of whilst i remove the old filter etc?
TieNN89
Postby TieNN89 » Mon Jul 21, 2008 6:49 pm
disconnect the fuel pump wire under the dash and start the car let it die was what i heard someone did
so fuel doesn't go everywhere
but i did that and fuel went everywhere anyway
do it quickly and you'll be fine
there might be instructions on miata.net s garage
AJ
Postby AJ » Mon Jul 21, 2008 6:55 pm
be ready when you pull the line off from the engine side & pinch it off by doubling over & holding it doubled over with a clothes peg, that'll stop the line draining back (the reason Wuns method didn't work is that fuel needs to be pumped to the engine, it won't necessarily suck it all up)......being an electric fuel pump there'll be some pressure behind it when you do pull it off, so wear some eye protection for the job.
oh, & don't light a cigarette, unless you have new for old replacement policy on your insurance :lol:
XMX5 Rogues
RG.net
Postby RG.net » Mon Jul 21, 2008 7:39 pm
i'll keep that in mind aj thanks :) anyone know the symptions of when the fuel filter needs replacing? i'm hoping fuel comsumption is one of them ?
silvermiata
Postby silvermiata » Tue Jul 22, 2008 10:42 am
changing fuel filter is a PITA, make sure car is not hot otherwise you might be shi**ing yourself under the car when you see premium unleaded fuming away on the hot exhauset pipe :) (bad bad experience) make sure you do not break the plastic clips holding the fuel lines to fule filter as you will reuse them...
for the fuel consumption, i think coil pack also has a big effect, if your coil pack is old, then fuel consuption goes up...
RG.net
Postby RG.net » Tue Jul 22, 2008 7:49 pm
silvermiata wrote:changing fuel filter is a PITA, make sure car is not hot otherwise you might be shi**ing yourself under the car when you see premium unleaded fuming away on the hot exhauset pipe :) (bad bad experience) make sure you do not break the plastic clips holding the fuel lines to fule filter as you will reuse them...
thanks for the heads up, if the coil packs end up being a problem then i might need to do some reasearch on some splitfires 8)
SuperMazdaKart
Postby SuperMazdaKart » Tue Jul 22, 2008 8:26 pm
\"picture says a thousand words\"
mx52nv
Purple Porsche Eater
Postby mx52nv » Thu Jul 24, 2008 12:56 am
Just thought I'd mention that opening your fuel cap to release any pressure would also help. I've done this hundreds of times but all on a hoist so I hope that is what you're doing.
Caffeine
Postby Caffeine » Fri Jul 25, 2008 2:02 pm
I used drill bits of appropriate size pushed into the fuel lines (blunt end in obviously) to block them temporarily while replacing the filter.
Another culprit maybe fouled injectors, run some injector cleaner through and see if it helps (i do that every year or so)
