Cat Converter
silvermiata
Cat Converter
Postby silvermiata » Mon Aug 04, 2008 2:23 pm
My stumbling, limited power looks like it is because of a clogged cat... does anyone use npower magnaflow cat:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&Item=190171307318&Category=43807&_trksid=p3907.m29
If so is it straight bolt on? how hard is it to put it on? need welding? and hows the performance?
thanks...
PUR157
Cat Converter
Postby PUR157 » Mon Aug 04, 2008 7:02 pm
Just by eye... if that's the product... it'll need flanges to be welded on for it to fit?
Exhaust shops should be able to do that for you no problem
Is it going onto a stock system or aftermarket?
Oneness of Man and Machine
Cat Converter
Postby orx626 » Mon Aug 04, 2008 7:02 pm
Hi there, I and Mokesta use one. Welding is definitely required. I assume performance is improved over a standard 80,000km unit I replaced, however I did replace the whole exhaust system and got quite a noticable improvement in performance.
Here's a couple of piccies....
and here's the thread on the install...http://www.mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=57&t=29490&start=45
Cat Converter
Postby sliq » Mon Aug 04, 2008 7:28 pm
it's going on a stock system (hopefully not for long)
silvermiata
Cat Converter
Postby silvermiata » Tue Aug 05, 2008 12:50 pm
well .. problem was fuel pump not the clogged cat.. so no need to change it for now:) thanks for the replies though...
mr_rotary
Cat Converter
Postby mr_rotary » Tue Aug 05, 2008 3:11 pm
I have a Magnaflow on my NA6. Was not a bolt in rather welded in however works great.
