NB8B 6 Speed Gearbox Issues
Garry
Postby Garry » Sun Aug 10, 2008 4:39 pm
Just a heads up. I was checking the rubber boots around the gear lever the other week and I remembered that Bevan had issues with the 4 top turret bolts on his gearbox being loose so I checked the ones on my gearbox and they were loose too. I tightened everything back up and noticed a marked improvement in shift quality. The little graunch the gearbox has always had when changing into 2nd and 3rd gears has been reduced considerably, even when cold. It's been over a week since I tightened everything up and all is still good. So while your in there changing boots it might be a good idea to check that the 4 turret bolts are firm. The two rear ones are easy to get to through the hole in the floor, the 2 front ones need a bit more creativity. Next time I have the mid brace off I will go in from underneath and check the 2 front ones again.
Craig
Postby Craig » Sun Aug 10, 2008 5:09 pm
Good tip there Garry! Might try it myself! 8)
bigdog
King of the kennel
Postby bigdog » Sun Aug 10, 2008 9:38 pm
Mine were loose too when I did my boots - seems quite common :frown: When I do the new lever bush I'm going to look at loctite or better washers to ensure it doesn't happen again.
TieNN89
Postby TieNN89 » Sun Aug 10, 2008 11:58 pm
thats interesting maybe thats why i can't get into 2nd when cold
altho mines 5 speed but worth a look i guess :D
kenson
Postby kenson » Mon Aug 11, 2008 12:33 am
Thanks Garry - I'll make sure I have a look
Another problem I had was that my power plant frame had a few loose bolts/nuts near the diff (actually one was missing). I added a temporary bolt and nut and it made a huge difference in shift feel
I've finally received the replacement parts from Japan (took 3-4 months) and have installed them. The shift is now so much softer and less notchy
Though I do sometimes find it hard to get into second gear still :cry:
blackster
Postby blackster » Mon Aug 11, 2008 3:50 pm
Have you tried getting to the front two bolts whilst the gear boot is off, with a flex 180 degree lock gear spanner?
Previous
04' MX5 SE.
02' MX5 Classic ed.
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Mon Aug 11, 2008 4:30 pm
^ I love my Kingchrome flex lock spanners. Best spanners ever!
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
blackster
Postby blackster » Mon Aug 11, 2008 5:11 pm
d-mag wrote:^ I love my Kingchrome flex lock spanners. Best spanners ever!
So do I, but I think its turning into a shameless plug :lol:
Previous
04' MX5 SE.
02' MX5 Classic ed.
Garry
Postby Garry » Tue Aug 12, 2008 10:08 am
ummm, no, because I dont have any. However, my birthday is coming up so any gifts will be greatfully recieved.
nick viner
NB8c 6 Speed Gearbox Issues
Postby nick viner » Mon Oct 13, 2008 8:44 pm
Took my rice rocket back to Penfolds Mazda to have it looked at . No dice , Slave OK: next service it will be left for them to rectify ( under warranty).
Looks like syncros are U/s.
Whilst on the subject. What do you guys think about mazda water pump versus after market?
Coming up for 100.000 Kms. What parts are good after market or should I go all mazda.
Looking at the dollars.
Do I need to do the belt rollers and do I go mazda belts too?
Cheers Nick
nick viner
Postby nick viner » Mon Nov 10, 2008 11:13 pm
I tried to remove the center console the other day to check the bolts on the top of the gearbox and couldn't get it off. Undid the two plastic pins either side up front and the screw in the little storage space further back. No dice . How does it come off and is this the way into the said bolts on the gear box?
wun911
Postby wun911 » Mon Nov 10, 2008 11:23 pm
one screw under the power window switch...
every ounce counts
oongie
Postby oongie » Tue Nov 11, 2008 1:23 am
wun911 wrote:one screw under the power window switch...
You need to pry out the power window switches with a very flat edge.
Last time a cooking utensil worked really well ...
90 NA6 98RWKW of fury 1.7L fury box
