Ignition Leads
tuned_to_fly
Ignition Leads
Postby tuned_to_fly » Tue Nov 11, 2008 2:10 pm
Hi all,
I am currently in the process of replacing all fluids and cheapish consumables on my 98 nb8a and have come to spark plugs and leads. I will probably go with some form of NGK spark plug but it is the leads that are doing my head in.
Mx5mania have Magnecor leads for $135-$175 (7, 8 or 8.5mm) which seem to be a popular choice however I have seen on miatamania.com they have 8mm Jackson Racing leads for US$45 or 8mm Cobalt leads for US$39.95. Are these leads just as good and what size best suits a weekend car/future very part time track car - I'm guessing 8mm is a good mid range option..
I'll be buying a few other things from miatamania shortly so postage isn't really a mega problem here either - I'm more concerned about quality. (And yes I have searched but I couldn't find exact answers to my questions)
Ignition Leads
Postby Okibi » Tue Nov 11, 2008 2:41 pm
My manga'cores have been fine. :mrgreen:
wun911
Ignition Leads
Postby wun911 » Tue Nov 11, 2008 3:13 pm
im happy with mine but it must have been the early ones mine dont seal properly at the top. (NB8B)
every ounce counts
Saffa
Vehicle: NA6 - Supercharged
Ignition Leads
Postby Saffa » Tue Nov 11, 2008 3:27 pm
I got mine for an NA6 from QLD Ignition Leads in Kallangur, got a choice of leads there I went with 8.5mm or 9mm. Paid about 150 (i think) a year and a bit ago, the guy makes them up for you on the spot.
FOR SALE>>93 NA6 FFS MP62 - NA8 Brakes, 4.3 LSD Torsen II.
http://mx5cartalk.com/forum/viewtopic.php?f=73&t=54518
tuned_to_fly
Ignition Leads
Postby tuned_to_fly » Tue Nov 11, 2008 3:50 pm
wun911 wrote:im happy with mine but it must have been the early ones mine dont seal properly at the top. (NB8B)
Is that the magnecores wun?
Thanks for the info everyone - keep it coming. So anyone use the Jackson Racing or Cobalts?
RG.net
Ignition Leads
Postby RG.net » Tue Nov 11, 2008 6:34 pm
i got some OBXR 10.5mm leads on mine, only cost me $70 too :) but that was before the dollar crashed.
tbro
Ignition Leads
Postby tbro » Tue Nov 11, 2008 8:41 pm
Tuned to fly,
Have you check out genuine Mazda leads.
Thats what I fitted when mine stuffed up (NA8) $60.00
Terry
bensale
Ignition Leads
Postby bensale » Tue Nov 11, 2008 8:57 pm
tbro wrote:Have you check out genuine Mazda leads.
x2 Thats what i did.
Is there a large advantage in running other than OEM?
www.othersideproductions.com
MxJadeMonkey
Ignition Leads
Postby MxJadeMonkey » Tue Nov 11, 2008 9:32 pm
I run Top Gun spiral wire 8.8mm leads on my NA6, have done for years now, never missed a beat. ever!
TOUCHING WOOD!!!!!
(the wood coffee table that is, not WODD as your all thinking)
1991 NA6 Velocity Blue (Ford Colour)
wun911
Ignition Leads
Postby wun911 » Tue Nov 11, 2008 11:01 pm
yeah they are magnacore ones blue I think 8mm, not 100% snug at the top I must have got an early batch have had them for about 2 years they work alright.
every ounce counts
mx52nv
Purple Porsche Eater
Ignition Leads
Postby mx52nv » Tue Nov 11, 2008 11:23 pm
MxJadeMonkey wrote:I run Top Gun spiral wire 8.8mm leads on my NA6, have done for years now, never missed a beat. ever!
Same here. Did fine at 120 rwkw or 220rwkw 8)
tuned_to_fly
Ignition Leads
Postby tuned_to_fly » Wed Nov 12, 2008 10:41 pm
I'll check the Top Gun ones out to throw another brand into the mix :? They all seem to list the same features and materials so I'm starting to think it really doesn't matter what brand...
SuperMazdaKart
Ignition Leads
Postby SuperMazdaKart » Wed Nov 12, 2008 11:23 pm
TOUCHING WOOD!!!!!
i got the same ones in the Familia. can't complain at all. even the normal TopGuns I had in the NA6.
madboy
Ignition Leads
Postby madboy » Thu Dec 18, 2008 2:37 pm
TOUCHING WOOD!!!!!
sorry about the old thread, but are these the standard 8mm top guns or the MAX300's? did these come with the cup or do you need to reuse, I have priced a set up at $125 for the MAX300's but the way the guy was talking its just a lead, no cup to fit over the plug and seal the hole. Don't really want to reuse red cups with blue cables!
tuned_to_fly
Ignition Leads
Postby tuned_to_fly » Fri Jan 02, 2009 5:11 pm
Well I finally bought a set of Jackson Racing leads and NGK spark plugs and tried to install today however I was only able to get one lead off as they are damn tight! When I reinstalled the one lead, I could get it off again quite easily so I'm assuming 10 years age manages to get them stuck on there quite well. Is there a particular method to remove them (ie maybe levering the bottom the the plug upwards) or is it purely brute force? Due to the tight area they are in I couldn't really think of much to do to help the situation...
Any ideas peoples?
