oil pressure sender socket size?
RG.net
Postby RG.net » Thu Nov 13, 2008 2:07 pm
anyone know the size for the damn oil pressure sender?
i have tryed 22mm, 28 and 34mm none work (well the 28 and 34 are intertwined but the 34 doesnt reach the bolt)
i really want my oil pressure gauge to work, i finally hooked up the water temp.
Locutus
Postby Locutus » Thu Nov 13, 2008 3:48 pm
22mm, but you will need a deep socket to get to the bolt.
btw, when it comes to removing the stock sender, socket extensions are your friend.
RG.net
Postby RG.net » Thu Nov 13, 2008 3:52 pm
Locutus wrote:22mm, but you will need a deep socket to get to the bolt.
are you sure? my 22mm is deep socket but the bolt was bigger then the socket :shock:
my car is NB btw, i have the "idiot" oil pressure gauge.
Locutus
Postby Locutus » Thu Nov 13, 2008 4:57 pm
22mm is the figure i found on a website when trying to get the idiot sender off my NA8.
i actually used an imperial 6 point socket. it was either 13/16" or 15/16".
RG.net
Postby RG.net » Thu Nov 13, 2008 5:40 pm
Locutus wrote:22mm is the figure i found on a website when trying to get the idiot sender off my NA8.
i found that off miata.net i think too, they stated a 22mm and 29mm socket. mmm i need to measure it somehow :lol:
Postby Mr Morlock » Thu Nov 13, 2008 10:52 pm
measure it with a vernier or calipers if you can get to it.
tbro
Postby tbro » Thu Nov 13, 2008 11:20 pm
Try these,
T&E Tools Part No 4019 1"/1/16" deep wall socket. Avail from any good tool shop. About $30.00
Oil Pressure and Stoplight Switch Socket
KD 2569 $6.50 US$
Removes oil pressure sending unit on most engines. 3/8" drive socket has a 1 and 1-1/16" hex opening plus recess to accommodate switch. Socket also fits some brake-light switches. Turn with a 15/16" wrench. Length: 3". Caution: Do not use with engine running. Do not use with power tools. For intended use only.
KD 2569 $6.50 US$
I've purchased these from my local mobile tool man.
Should be avail locally to you
Terry
Locutus
Postby Locutus » Fri Nov 14, 2008 9:44 am
Mr Morlock wrote:measure it with a vernier or calipers if you can get to it.
:lol:
if you thought the oil filter was hard to get to...
