New Hose Clamps for the SE
Fuzzlet
Postby Fuzzlet » Thu Nov 20, 2008 12:43 pm
One check that all the SE (and well anyone with a turbo) is your hose clamps. I had one decide to blow off on me yesterday (the oem clamp snapped...). So off to Auto One to buy a couple of hose clamps, since I thought it might be a good chance to upgrade a few others whilst I was at it
This was another hose that looked ready to blow off aswel:
Turns out it was no-where near:
New clamps Installed:
One thing I did find interesting though, was how clean the inside of the pipes were (considering all the complaints Ive heard about the factory oil catch can not being up to the job):
blackster
Postby blackster » Thu Nov 20, 2008 3:05 pm
The first thing I replaced were the factory clamps on the charge intake with T-bolt clamps. As far oil in the charge intake, mine appears as yours.
Previous
04' MX5 SE.
02' MX5 Classic ed.
PASHN8
Postby PASHN8 » Thu Nov 20, 2008 4:50 pm
Agreed with Phil, the conventional worm drive clamps are crap! I've upgraded ALL clamps to T-bolt clamps now, set & forget!
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
timk
Postby timk » Fri Nov 21, 2008 1:32 am
Also watch your temp sensor near the throttle body, mine has almost blown out!
Fuzzlet
Postby Fuzzlet » Fri Nov 21, 2008 1:34 am
Yea I've had to fix up my temp probe a few times now...When I wind the boost up I'll invest in some decent clamps, but for now these will do the job (heck anything is better than the standard spring clips)
Juffa
Postby Juffa » Fri Nov 21, 2008 11:54 am
I'm using constant torque clamps on all of my FI hoses and the upper coolant hoses. These are the same clamps as used on the SP.
http://www.jeenterprise.com/Products/Cl ... mp_CT.html
Not cheap at around $12-$15 each, but they are great. I bought my from an importer in Oakleigh, Melb.
J
