Gearbox Bearings need replacement, any recomendations?
RG.net
Postby RG.net » Mon Dec 08, 2008 8:49 pm
hi guys,
i bought a 6 speeder a few months ago, and its finally time to get the bearings replaced in it, the only problem is i dont really know any gearbox rebuilders, anyone have any recomendations? i'm pretty sure its the skipknot (something like that) bearing that needs to be replaced.
cheers
bigdog
King of the kennel
Postby bigdog » Mon Dec 08, 2008 10:14 pm
Could it be the spigot bearing you're referring to? This is not in the gearbox, but in the centre of the flywheel where it supports the end of the gearbox input shaft. It should have been replaced when the clutch and flywheel were fitted - Its easy to get to when the gearbox is removed. What are the symptoms that make you think you need to replace it?
RG.net
Postby RG.net » Tue Dec 09, 2008 5:13 pm
bigdog wrote:Could it be the spigot bearing you're referring to? This is not in the gearbox, but in the centre of the flywheel where it supports the end of the gearbox input shaft. It should have been replaced when the clutch and flywheel were fitted - Its easy to get to when the gearbox is removed. What are the symptoms that make you think you need to replace it?
yeah that sounds right, i bought the gearbox as is at a cheap price, the owner said that a bearing needed to be replaced, pretty sure it was the spigot. he said that shifting was twice as hard, everything else was fine though.
Rotary
Postby Rotary » Tue Dec 09, 2008 10:41 pm
MX It's not a part that's on the Gearbox, it's on the crankshaft
RG.net
Postby RG.net » Thu Dec 11, 2008 4:03 pm
Rotary wrote:MX It's not a part that's on the Gearbox, it's on the crankshaft
you lost me mate
Boags
Postby Boags » Thu Dec 11, 2008 5:09 pm
you lost me mate
The spigot bearing is not part of the gearbox. The spigot is fitted to the flywheel and "guides" the gearbox shaft.
RG.net
Postby RG.net » Thu Dec 11, 2008 6:34 pm
Boags'MX5 wrote:
you lost me mate
ok got it, i bought the gearbox without a flywheel/clutch so i'm guessing it doesnt even have a spignot bearing ? :lol:
edit, from PO
gearbox was in superb nick but somehow whoever that installed the box for me forgotten the ever important spigot bearing
result:Vibration from the engine/clutch stuffed one of the bearings in the gearbox
Syncros and gears are still OK, bearings need changing.
it's hard to get into 1st and 4th gear (i still drive around with it on the car, just double the shifting effort)
good for rebuild/spares etc
Postby Mr Morlock » Thu Dec 11, 2008 6:49 pm
this is not making much sense. Your gearbox clearly has a question mark hanging over it and will have to come out for fault diagnosis. Probably best that you take it to a gearbox repairer to at least observe the in situ problems. Consider that it is almost certain it will have to be removed and then stripped for examination- you might ask for $ guide for rectification though you will almost certainly get a response along the lines of "depends what we find".
Fatty
Postby Fatty » Thu Dec 11, 2008 6:53 pm
maybe the guy just meant the thrust bearing?
RG.net
Postby RG.net » Thu Dec 11, 2008 8:08 pm
for a start the gearbox is out of the car, and the thread was made in regards to workshops that deal with mx-5 gearbox's, but into more of a diangnostic thread :lol:
Rotary
Postby Rotary » Thu Dec 11, 2008 9:59 pm
bearings shouldn't affect it's shifting into certain gears. worn bearings would make a whining sound.
Worn or Syncrhros or other internal problems can give that effect
Describe in detail how it was when changing,
Did it stop moving into the selected gear then after a hard push jump into place?
Was it just Heavy in shaft movement?
Did it crunch sometimes when going into the hard gears?
Did it whine in neutral or whilst in a certain gear?
That may help to narrow it down
MX5CHIC
Postby MX5CHIC » Thu Dec 11, 2008 10:43 pm
The small bearing located in the Flywheel is called the Pilot Bearing if I recall correctly, mine began to seize a few years ago and if that was the problem you will hear a spine tingling screeching sound - it scared the hell out of me when it first happened :shock:
My gearbox became hard to shift when my clutch cylinder began to leak fluid, I thought at first that it was my gearbox going wrong.
RG.net
Postby RG.net » Fri Dec 12, 2008 6:31 am
guys, you have this all wrong. the gearbox is not in the car, the car is currently an automatic, i bought the gearbox as is, and thats all the PO gave me to work with, now does anyone have any recomendations on workshops that do good work?
