Crisis Averted and Fix for young players !
kazjim
Postby kazjim » Thu Jan 01, 2009 7:24 pm
So, for the last two weeks of driving my Na6, it occasionally developed a little 'stutter' ... a very rythmical surging ...
would become more pronounced as the ambient heat went up and the fuel guage went down ...
My first thought was to give the lil beast a full service, all filters, oil, fluids etc.. made a HUGE difference, BIG power gain, much smoother and happier ....
.....but the stuttering returned
Until today ... was out in the stupid heat, and it started ....
So was thinking that maybe the fuel pump was struggling with the heat ..... fix ? pour in some cold fuel ....
as I opened the fuel cap, a loud sucking sound .......
Guess my Vented Fuel cap isnt as vented as I thought :roll: Fel pump was fighting against the vacuum of a missing 20 liters of fuel !
Problem fixed ....
Short story:
If you get a weird surging in the heat and low fuel, just unscrew your fuel cap and continue on your way !!
Now, a quick question, can anyone post a pic of their NA6 Fuel cap to see if mine is a 'real' one or a 'servo-special' ?
Cheers all
J
If my calculations are correct, when this baby hits eighty-eight miles per hour ... you're gonna see some serious s**t.
StanTheMan
Postby StanTheMan » Thu Jan 01, 2009 8:18 pm
I get that all the time when re-fuelling. On hot days but the tank is nearly empty. I've never had performance issues though.
My fuel cap is orange. No pic avail. sorry
TieNN89
Postby TieNN89 » Thu Jan 01, 2009 8:27 pm
I get the sucking sound too on my NB8A
not much tho even tho even tho the tank is down to empty
cap is black
Red Dragon
Postby Red Dragon » Fri Jan 02, 2009 11:07 am
Here's a picture of mine so far have not had your problem
Postby Jeo » Fri Jan 02, 2009 12:00 pm
Same cap here ^^^
Haven't enountered the problem either
StanTheMan
Postby StanTheMan » Fri Jan 02, 2009 12:28 pm
^^^^X3
kazjim
Postby kazjim » Fri Jan 02, 2009 12:33 pm
Yea, thats the same as mine, so I guess its just blocked or the Charcoal canister is blocked and not venting properly ...
Thanks guys !!
J
Postby Okibi » Fri Jan 02, 2009 2:48 pm
I seem to remember reading that with the NBs if you don't tighten up the cap properly you can get a CEL code.
marcusus
Postby marcusus » Fri Jan 02, 2009 4:09 pm
Okibi wrote:I seem to remember reading that with the NBs if you don't tighten up the cap properly you can get a CEL code.
What's a CEL code?
Postby Jeo » Fri Jan 02, 2009 5:23 pm
Check Engine Light or something to that effect I believe
Basically where a little light somewhere, typically either on the dash or the ecu itself, flashes a cartian number of times to explain that something has gone wrong. Normally a series of long and short flashes which then correspond to a specific problem in the service manual.
kazjim
Postby kazjim » Sat Jan 03, 2009 7:13 pm
Nahh, definitely sucking, same thing used to happen on my 68 Mini - non vented cap ... every 300 Miles you had to open the fuel cap or the car would just stop running :lol:
I'll get around to checking the Vapour Canister and see if there is any blockage there . . . otherwise I'll try a replacmement cap ...
J
