Extractors Glowing Red
TieNN89
Postby TieNN89 » Thu Jan 01, 2009 10:08 pm
Should I be worried?
I went up Mt Cootha (for those that know) thru the back where Channel 10 ABC is not the lookout way
Anyway I went up Mt Cootha in 3rd gear doing erh cough speed limit around the 4000-5000rpm if i recall correctly
stopped infront of ABC had a look under my bonnet and i noticed a bit of the extractor was glowing red
not the whole extractor but where the extractors go from 4 to 2
Should I be Worried?
My factory water temp gauge was sitting where i usually sits
TieNN89
Postby TieNN89 » Thu Jan 01, 2009 10:22 pm
Heres the bits where I saw it go red tonight not much went red tho
greenMachine
Postby greenMachine » Thu Jan 01, 2009 10:57 pm
Just keep that aircon line away from it.
Ask me how I know :oops: , or, better still, don't... :lol:
:mrgreen:
TieNN89
Postby TieNN89 » Thu Jan 01, 2009 11:04 pm
greenMachine wrote:Just keep that aircon line away from it.
:mrgreen:
mmm not asking how you know but what was the results :D
any tips on how to keep the aircon line away?
RG.net
Postby RG.net » Fri Jan 02, 2009 12:00 am
:mrgreen:
take it out :D
NMX516
Postby NMX516 » Fri Jan 02, 2009 12:49 am
AZNTieN wrote:Anyway I went up Mt Cootha in 3rd gear doing erh cough speed limit around the 4000-5000rpm if i recall correctly
4-5000rpm in 3rd equates to 50km/hr??!! :shock: :shock: You must have one very low diff ratio there!! :lol:
TieNN89
Postby TieNN89 » Fri Jan 02, 2009 1:05 am
wait it might even be second lol
adamjp
Postby adamjp » Fri Jan 02, 2009 3:36 pm
No problem.....glowing red is normal when you work the engine hard at, er, cough, legal speeds, cough.
There is a classic advert from the very early seventies of the E49 Hemi six pack (245cubes with 3 x 45mm Webers) on the dyno in italy as they tuned the webers and the extractors were bright red. They only made 140 E49s, try finding one now.
Adam
Hellmun
Postby Hellmun » Fri Jan 02, 2009 5:48 pm
See I'd expect it on a turbo car or on a dyno when there's no airflow at all. However going up a hill on just 4000-5000rpm. I've ran the car for 20 minutes at a time on the track and not seen any glow. That's never going below 4500rpm the whole time either. Usually the glowing infers a turbulent spot I thought.....
TieNN89
Postby TieNN89 » Fri Jan 02, 2009 7:05 pm
i'll make sure i bring my camera next time and take a snap while its glowing red
ben wilson
Postby ben wilson » Fri Jan 02, 2009 8:51 pm
Hellmun wrote:See I'd expect it on a turbo car or on a dyno when there's no airflow at all. However going up a hill on just 4000-5000rpm. I've ran the car for 20 minutes at a time on the track and not seen any glow. That's never going below 4500rpm the whole time either. Usually the glowing infers a turbulent spot I thought.....
At a track you tend to be doing higher speeds for the revs than on a mountain. High revs + low airspeed = hot. Probably nothing to worry about.
Fuzzlet
Postby Fuzzlet » Fri Jan 02, 2009 8:57 pm
I was able to get the dump pipe and rear housing to glow on my NA (Running an SP manifold + turbo)
madboy
Postby madboy » Sat Jan 03, 2009 12:51 am
headers are wrapped, if the heat can't dissipate then its going to get allot hotter, unless they are stainless i wouldn't be to worried
TieNN89
Postby TieNN89 » Sat Jan 03, 2009 1:49 am
yep there wrapped with DEI branded stuff
there mild steel
when i got my exhaust done the exhaust shop said he doesn't recommend stainless on extractors because they crack due to heat etc etc
so i went the mild steel and stainless the rest
i shoulda HPCed it :[
anyone know how much it cost
i just don't like the down time :[
Postby Regie » Sat Jan 03, 2009 11:04 am
heres a pic of my extractors after a hour of dyno time a few years ago (crappy phone camera)
