Idle adjust screw std seting
Tedsmx5
Vehicle: NA8 - Supercharged
Postby Tedsmx5 » Mon Jan 26, 2009 12:38 am
Can someone tell me how many turns out the " Idle adjust screw" is set to on a standard NA8?
I have a aftermarket ECU and would like to setup the air screw to use the same (standard) adjustment range.
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
Postby 93_Clubman » Mon Jan 26, 2009 2:17 pm
Various pubs just talk about turning the screw to get 850rpm +/-50rpm idle with the GRN & TEN jumpered in the engine bay diagnostic box. However, from when I partially dismantled & cleaned the TB on my NA8, the screw was around one turn anticlockwise from full clockwise, so screw it all the way in & back-off one turn as a starting point to fine tune idle. From memory, I've read idle is usually found between one & one & a half turns, but mine was less than one turn. <www.miata.net> might be able to shed more light.
Tedsmx5
Postby Tedsmx5 » Mon Jan 26, 2009 4:36 pm
Thank you that’s all I need. I'll adjust mine to one turn then use the Idle adjust in the ecu to bring my idle up to 850-900rpm, this is so the PWM signal is of a similar rate to the standard ecu. :?: Clear as mud I think :lol: sorry.
Ted.
