Possibly done a head gasket. Fix it or get another engine?
Adam_NAclubman
Postby Adam_NAclubman » Tue Feb 10, 2009 7:08 pm
Speaking to Mike Coppola he said that when his BP did a gasket it was pretty much ruined, so he just replaced it.
Mine has boiled a coupe of times, first when the heater hose went, then twice since then when the thermostat died. Now its using a bit of water and feels quite sluggish.
I was planning on fitting my AVO kit soon, so am I possibly better off finding another BP, fitting the kit and doing the belts, water pump etc while its out of the car then fitting it? Is this potentially going to cost me less than getting my engine fixed? It also has the oil leak from below the CAS
grump
Postby grump » Tue Feb 10, 2009 7:51 pm
If you can afford to have your car off the road for a couple of months, ( I can't ) then I would suggest getting your engine rebuilt. It's better the devil you know than the devil you don't know
SuperMazdaKart
Postby SuperMazdaKart » Tue Feb 10, 2009 8:00 pm
BPT swap?
http://fordlaser.com/viewtopic.php?t=71309
of course get the compression/leakdown test to be sure if you can
Adam_NAclubman
Postby Adam_NAclubman » Tue Feb 10, 2009 9:48 pm
I thought it had been settled that swapping in a Familia motor was more trouble than its worth?
SuperMazdaKart
Postby SuperMazdaKart » Tue Feb 10, 2009 9:59 pm
well, you'll have plenty of time to work on it :)
Adam_NAclubman
Postby Adam_NAclubman » Tue Feb 10, 2009 10:05 pm
No I won't, I'm doing Masters this year
SuperMazdaKart
Postby SuperMazdaKart » Tue Feb 10, 2009 10:20 pm
could always take the shortcut, refreshed MX5 head onto BPT block.
or just goto Chris Milton engine rebuilders.
GP
Postby GP » Wed Feb 11, 2009 1:17 pm
Head gasket isn't a big job or anything, That's what I would be doing
Graham
madboy
Postby madboy » Wed Feb 11, 2009 4:18 pm
Well, if you've already boiled it 3 times? and you says its acting sluggish? and using water? common sense would say you've probably done some damage, more than likely not just to the gasket. cooking a motor is not a good thing as there are so many things that can be damaged, just replacing the head gasket may not be the easy fix(been there done that, didn't work, ended in a full rebuild).
If your planning to slap a snail on the side, I'm with grump, rebuild, build the motor to suit the snail. A fresh build is always prefered if your adding boost, saves having to rebuild after the snail is added because oil starts gushing out between the head and block because the old and tired gasket couldn't take it(not me!).
Good luck btw, there is boost in my future somewhere...its just along way off!
MB
sabretooth
Postby sabretooth » Fri Feb 20, 2009 11:08 am
I suspect I've done a headgasket through hoses bursting and subsequent overheating - thing is I've never let it run with the gauge on full hot.. *shrug*
I'm just going to remove the manifolds and remove the head, clean things up and put it back together again with a new gasket.
randymx5
Postby randymx5 » Fri Feb 20, 2009 11:56 am
Adam_NAclubman wrote:I was planning on fitting my AVO kit soon, so am I possibly better off finding another BP, fitting the kit and doing the belts, water pump etc while its out of the car then fitting it? Is this potentially going to cost me less than getting my engine fixed? It also has the oil leak from below the CAS
This is what happened to me but ~10 or so years ago. I was lucky enough to source a new 1.8L engine from just Jap who at the time had brought a bunch of new random engines from O/S.
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
madboy
Postby madboy » Fri Feb 20, 2009 3:27 pm
sabretooth wrote:I suspect I've done a headgasket through hoses bursting and subsequent overheating - thing is I've never let it run with the gauge on full hot.. *shrug*
it only takes seconds and the wrong temperature for rings to loose their temper, once they've gone soft they are simply no good any more.
I am sure they are checks to see how much blowby your getting, you don't need to be blowing smoke to have stuffed rings or valves
greenMachine
Postby greenMachine » Fri Feb 20, 2009 4:20 pm
Nthing the rings issue - do a compression/leakdown, but I'd be pulling the pistons anyway and fitting new rings, unless you just want to throw it together and flog it off ...
:mrgreen:
Adam_NAclubman
Postby Adam_NAclubman » Sat Feb 21, 2009 12:34 am
I think what I'll be doing is chucking a new water pump, timing belt, plugs etc in the BP I bought the other day, put the kit on it, run lowish boost, tune it to be safe rather than max power and drive it. Over time I'll pull down my original engine and build it up then eventually chuck it back in.
Bought a HD organic Xtreme clutch today
SuperMazdaKart
Postby SuperMazdaKart » Sat Feb 21, 2009 1:07 am
Good choice that clutch. I had my Familia booked in to get one of those installed last week at All Brake & Clutch. Turns out it didn't need it since the problems ended up being with the clutch cylinder not the current clutch itself.
