Wabbly gear stick...
roddclarke
Postby roddclarke » Wed Mar 25, 2009 4:22 pm
Hi All,
I have just bought another MX5 :) this one is a 2001 NB8B in Crystal Blue.. but anyway..
when it is in gear, any gear, you can move the gear leaver about 1 to 2 cm side to side. the gear changes are fine, and i have just replaced the nylon bush thing on the bottom of the gear leaver and it made no difference.
What are your thoughts or ideas on what it could be?? and how to fix it.
thanks
"If your in 5th, your not having fun"
1:13.26 at Wakefield, 52.92 at OP south, 1:25.97 at OP GP, 1:56.78 at EC.
previously 2002 Supreme Blue... now 2001 Crystal Blue...
Postby sliq » Wed Mar 25, 2009 5:50 pm
welcome back to the fold mate. didn't think i'd be seeing you in one so soon! 8)
Steampunk
Postby Steampunk » Wed Mar 25, 2009 7:53 pm
check the three bolts that connect the stick to the geabox housing as they can come loose fairly easily.
If they are loose, then a bit of threadlocker and/or spring washer will do the trick
roddclarke
Postby roddclarke » Thu Mar 26, 2009 10:45 pm
thanks.. no those bolts are tight.. i had to undo them and do them up when i did the nylon bush replacement.. so its not them..
although the rubber boot that is held in by those 3 bolts and attaches to the gear shifter is torn.. so i will be ordering a new one of them.. but i dont think a torn boot could cause this issue.. mmm
still to find it..
Postby Okibi » Fri Mar 27, 2009 1:16 am
The boot will probably be it.
Garry
Postby Garry » Fri Mar 27, 2009 8:21 am
Also check the 4 bolts on the top of the gearstick turret. They would have to be pretty loose to give you that much play but they do have a tendency to work themselves loose.
roddclarke
Postby roddclarke » Fri Mar 27, 2009 1:09 pm
ok, will try that.. i just bought a new boot, the 3 bolt one to the gearbox that was torn..
will fit it tomorrow and let you all know if it works :)
i hope so :)
and will also re-tighen all the bolts i find..
StanTheMan
Postby StanTheMan » Fri Mar 27, 2009 1:49 pm
your back!!!!!
sweet. You've just been recruited for underbelly3... :mrgreen:
roddclarke
Postby roddclarke » Sat Mar 28, 2009 12:02 am
haha.. underbelly 3 ???
i know im getting fat.. but :mrgreen: :mrgreen:
zoomzoom
Postby zoomzoom » Sat Mar 28, 2009 1:55 am
Check the little nylon bush at the bottom of the shifter too.
Tim
Postby Okibi » Sat Mar 28, 2009 1:24 pm
roddclarke wrote:... i have just replaced the nylon bush thing on the bottom of the gear leaver and it made no difference...
Hellmun
Postby Hellmun » Sat Mar 28, 2009 3:07 pm
How tight was the shift-bush when you put it in? When I replaced mine it was DAM tight and it's what really reduced the flex left and right on the gearstick. My boots are both torn but then I don't really care so much. It's a track car...it probaly won't have a centre console much longer so there'll be more than enough heat just in the tunnel.
If you can move the stick with it in gear left and right that much then it's not something in the gearbox. It's got to be somewhere in the stick itself so make sure the bush is seated. My boots are torn and it made no difference so it should be unrelated.
So you coming upto the next trackday in May with the new car?
roddclarke
Postby roddclarke » Mon Mar 30, 2009 1:53 pm
Ok, done the boot cover as well and checked it out while the gear stick was out..
the play is on the gearbox or selector shaft.. as i took the gear stick out, and put my finger in the gearbox and could feel the play with my finger in where the Nylon bush sits.
so its something in the gearbox with the selector shaft or somthing.
I will take it to a track day.. but after August...
Postby Mr Morlock » Mon Mar 30, 2009 3:21 pm
Gearbox expert I am not but your gearchange should have the feel of being springloaded ie requires pressure to move to left and right and of course to engage 5th 6th or reverse and whata happens when you select reverse? . I think you will get a fairly fast response by checking one of the pros familiar with gearboxs. Alternatively try a shop manual or even generic trouble shooting.
Users browsing this forum: No registered users and 20 guests
