CALLING ALL NA8 owners!!!!
philz
Wheel guru
Postby philz » Thu Apr 02, 2009 6:59 pm
Has anyone used an NA8 coilpack on an NB8a before?
I believe the NB8A has 3 pin coil pack
Whereas NA8 pre 1995 have 4 pin, 95+ has 3 pin.
I know that the 4 pin coils, has an extra pin for the tach signal.
Can someone with an NA8 please list the colours on coil pack plugs from left to right? 3 or 4pin. (Total of 6 or 8 wires- the colours are....brown, black, black/white, brown/yellow ( 4pin has extra blue wire)
Steampunk
Coil Pack NA NB interchangeable?
Postby Steampunk » Fri Apr 03, 2009 12:05 am
philz wrote:I believe the NB8A has 3 pin coil pack
Correct
I'm not with my car atm, so I can't help with your wire/colour query.
Are you in need of a late NA8, three-pin, coil pack? If you want one brand-spanking new, genuine Mazda OEM, at a good price, send me a PM :wink:
philz
Wheel guru
Postby philz » Fri Apr 03, 2009 12:42 am
I'm in need of an NB8A coilpack, I've already got a coilpack, but they are both different, 4pin NA and original 3pin NB.
From what I can see, if the wiring is correct, and since 1.8L have ignitiors already in the coilpack, I don't see how it can't work, unless the ignitors in the NA is more weaker/stronger than the NB?
Thanks 1red5, could you please check the wiring.
On my NB it's:
(coil 4/1) Brown/yellow, Black, (nothing), Black/white................(coil 2/3) Brown, Black, (nothing), Black/white
edit: wrong wire colour.
philz
Wheel guru
Postby philz » Fri Apr 03, 2009 7:21 pm
BUMP
No one owns an NA8?
Postby 93_Clubman » Sat Apr 04, 2009 4:59 pm
From drivers side to passenger on Aust delivered '93 NA8: 1st plug: brown+white, black, brown, blue. 2nd plug: brown, black, brown+white, blue.
philz
Wheel guru
Postby philz » Sat Apr 04, 2009 5:54 pm
Cheers, are you sure it's brown/white?
Because on NA wiring schematics it says there is only brown/yellow, maybe wrong lighting.. makes it look like white?
But from what I can decipher, It's the same as the NB plug.
As I already know that
Brown/yellow, and brown: Trigger
Black: Ground
12V: Blue for NA, Black/white for NB
Tach for NA 4pin: Black/white
So the wiring is the same position... Trigger, Ground, (nothing/Tach), 12V
Postby 93_Clubman » Sun Apr 05, 2009 1:14 am
philz wrote:are you sure it's brown/white? Because on NA wiring schematics it says there is only brown/yellow, maybe wrong lighting.. makes it look like white?
Lighting wasn't great it was in garage with handheld 240v lamp - as you know the wires are not the most accessible & over 15 years old, so could be brown + yellow.
philz wrote:So the wiring is the same position... Trigger, Ground, (nothing/Tach), 12V
From drivers side to passenger on RHD '93 NA8 (i.e from left to right standing at front of vehicle looking at the coilpack): 1st plug: brown+white, black, brown, blue. 2nd plug: brown, black, brown+white, blue.
philz
Wheel guru
Postby philz » Sun Apr 05, 2009 8:27 am
Thanks Clubman, I appreciate your help taking time to look. :D
Did Australia only sell one Na8?
Postby 93_Clubman » Sun Apr 05, 2009 1:37 pm
philz wrote:Did Australia only sell one Na8?
Depends what you mean, but the following might help:
Australian MX5 Sales:
1993: 453 NA6 & NA8;
1994: 404 NA8;
1995: 196 NA8;
1996: 241 NA8; &
1997: 118 or 206 NA8 (depending on source).
MX5-1.8-BP-9/93-12/94--JMONA30P300100001-200000
MX5-1.8-BP-12/94-?/9?--JMONA30P400100001-200000
MX5-1.8-BP-?/9?-11/97--JMONA30P500100001-200000
Difference in VIN used to delineate between evolutionary releases of the NA8.
So the answer to your question is no, but then again your question might have been rhetorical...
Users browsing this forum: No registered users and 20 guests
