Possible Oil Leaks
Cruisin Newy
Possible Oil Leaks
Postby Cruisin Newy » Tue Apr 07, 2009 11:47 pm
Hi ,
Been looking for a Mx5 in 1.8 L 98/99/00 models and found many have a seem to be leak under the crank pulley and build up of grease and oil on the bash tray under front of engine. Is this a thing to be concerned about or would be retified if 100 Thousand service when replacinmg the Belt / water pump / seals etc.
cheers
Mark
Now NC3 PRHT auto Krystal white
Cruisin Newy
Newcastle NSW
JBT
Possible Oil Leaks
Postby JBT » Wed Apr 08, 2009 5:34 am
The front seals (cam and crank) are easily replaced during cam belt replacement. That should stop any oil leaks from that end.
Possible Oil Leaks
Postby bruce » Wed Apr 08, 2009 10:22 am
Could be the remnants of spilled oil when topping up?
sirbob
Possible Oil Leaks
Postby sirbob » Thu Apr 09, 2009 1:41 pm
Or the far more likely case of spilled oil from removing the oil filter from the woefully poor factory position under the inlet manifold.
Seriously, why did Mazda put it in such a terrible place to reach?
Now driving a Grand Vitara whilst waiting for the elusive Black SE
Garry
Possible Oil Leaks
Postby Garry » Thu Apr 09, 2009 3:29 pm
The engine was originally designed for an east west application. In that configuration the filter is quite easy to get to.
Possible Oil Leaks
Postby Okibi » Thu Apr 09, 2009 3:50 pm
I wonder if there'd be a market for a hard pipe remote oil filter kit, rather than one with hoses have a pair of solid pipes that sit the filter next to the intake just behind the strut top. I guess the only trick would be designing the system so that it could strew into an adaptor on the engine easily. It could even have a built in catch tray for any drips when it's being removed.
Users browsing this forum: No registered users and 22 guests
