When I took the shifter out and took the brass bush out this is what it looks like now
normal?
its from my NB8A 5 Speed which has an IL Motorsport Quick Shift Kit fitted to it
sliq wrote:what the fudge man!
have you got a quick shifter?
maybe you didn't fit the busher in properly. i remember the first time i fitted mine, it was very clunky, so i knew i had fitted it in wrong.
second time round it was as smooth as silk.
AZNTieN wrote:
:S how can you fit it wrong :S
you just put it in drop the shifter in and its all good isn't it :S
OVERDRAWN wrote:Hi If you have a Quickshift it would appear that it has been incorrectly fitted, ie too high and the bottom of the stick has not fully engaged in the bush
AO
Users browsing this forum: No registered users and 22 guests
