does anyone know what this part is called on a short shifter?
and perhaps where to buy another one?
its the white plastic bit that sits inside the ball of the gear stick & stops it rotating around in the gear box
short shifters
short shifters
short shifters
viewtopic.php?f=29&t=34784&p=450908&hilit=short+shifter#p450908
You might be better off calling Richard and seeing if he has an oem one. Replace your one with the oem plastic. Worked for me.
- Steampunk
short shifters
Doh... I thought I had a spare shifter lying around that you can take the bushing from.
