Leaking rear main
davo5
Leaking rear main
Postby davo5 » Mon Jun 22, 2009 9:24 pm
Hey guys,
Replacing a clutch, before we started i noticed the tiniest wet patch of oil at the bottom of the engine / bellhousing the size of a 50 cent piece.
We get the flywheel off and of course find this:
Is it for sure the rear main, or are these engines known to have sump gasket problems around the seal holder assembly?
Has anyone ever replaced a rear main using a self tapping screw extraction method? I really don't want to remove the seal holder as doing so (if it can even be done without removing the sump) looks like it would really perturb the sump gasket.
Small wires make big fuses.
OMY005
Leaking rear main
Postby OMY005 » Tue Jun 23, 2009 11:42 am
davo5 wrote:Has anyone ever replaced a rear main using a self tapping screw extraction method? I really don't want to remove the seal holder as doing so (if it can even be done without removing the sump) looks like it would really perturb the sump gasket.
The method described above works well as the seals don't seem that tight a fit.
Andrew. :D
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Leaking rear main
Postby 93_Clubman » Thu Jun 25, 2009 2:36 pm
As you can see from daffy's last post in the following thread he has issues with his real seal after recent replacement. If you go back a page or two in his thread you'll see some tips in relation to rear seals.
viewtopic.php?f=29&t=35381&start=150
