Mokesta wrote:MX-5 Plus have a beautifully machined re-route spacer for the rear of the head.
M
Pics of spacer please?
I'll send them an email about sending one down to Sydney. I don't really need warranty, etc just the part...
The reason for coolant reroutes (especially the way the OP has posted) is to remove the mixing manifold at the front of the engine.
This mixing manifold causes an inbalance in coolant flow in the engine, and hotspots form at the rear outlet. Think about it, there is one inlet at the bottom of the water pump (below the p/s pump above the a/c compressor) that is fed with cooled coolant from the radiator. It then has 2 possibilities to exit the engine, from the front of the engine and from the back of the head. Not only that, the hot coolant coming from the back of the engine, then mixes in with the cold coolant heading in to the engine again (this is necessary even with the reroute otherwise it will take an eternity to warm up and to pressurise the system).
Ok the thermostat is located on the return path to the radiator at the front of the engine, slightly preventing the cold coolant (as it is a restrictor) from just flowing straight to the top of the radiator.
So a spacer on the back of the engine to allow a thermostat in it and the front outlet blocked off would allow a front to rear coolant flow which would reduce the possibility of hotspots.
Disclaimer: This is only my opinion and understanding of flow principles from working (and breaking) cars. I take no responsibility for anyone breaking their bits. I only have overheating issues after extended hard driving (ie: 30 minute track sessions, 2-3 hour spirited runs) with a standard radiator .
