NPower Exhaust need advice
mxfive
Location: Brisbane Northside - Aspley, Queensland, Australia
Postby mxfive » Sun Jul 12, 2009 5:24 pm
Need advice. Thinking about an exhaust upgrade and after reading forum have decided upon the NPower system:
http://www.nahux.com/NPOWER/product.php?part_no=H-NA6CE
http://www.nahux.com/NPOWER/product.php?part_no=91005
http://www.nahux.com/NPOWER/product.php ... o=MO225-NA
Are these all the parts I would need?
Will these fit with the existing pipes and other existing fittings?
I like to do as much of the maintenance work on my cars as possible is this just a bolt on job? Any guides available?
RG.net
Postby RG.net » Sun Jul 12, 2009 5:38 pm
Sure is.
Not sure if the midpipe is seperable from the cat or not. Either way, if i wanted a full exhaust setup, i would want a new midpipe made that is bigger then OEM.
the extractors and muffler are designed to work with a stock midpipe (i.e bolt up)
tbro
Postby tbro » Sun Jul 12, 2009 6:23 pm
Hey Grant,
I'd have a word to Danny from MX5Plus( orx626 on here), they are the NPower dealer for Brissy.
You will need to have a new midpipe made up in 2.25in pipe and flanges welded to the midpipe and cat.
Danny can help with these, just tell him you want Terry's system!!! :lol: :lol:
With the extractors, I personally would use a mild steel extractors and have them thermocoated to increase efficiency.
Stainless extractors have a tendency to crack after a while due to heat retension.
BTW, was good to meet you yesterday!!
Terry
mxfive
Postby mxfive » Sun Jul 12, 2009 6:46 pm
tbro wrote:Hey Grant,
Terry
Hey Terry,
Thanks for that, will do. :D
Regards,
Grant
tbro
Postby tbro » Sun Jul 12, 2009 7:44 pm
Suppose you could always have a set of these made,
These extractors were made, fitted and then taken to the track in the same condition it finished after a 1 hour race,
The improvement. ...................................................
.........3.6seconds :shock: :shock:
Didn't think extractors could make that sort of difference, kind of makes a mockery of the experts saying extractors don't make much diff to a 1.6 motor!!!!!!!!
Terry
rascal
Postby rascal » Mon Jul 13, 2009 3:28 pm
tbro wrote:These extractors were made, fitted and then taken to the track in the same condition it finished after a 1 hour race,
Terry
You must have had an 'extremely' restrictive system before, or the track conditions had changed since the last run, to be able to gain 3.6 seconds by this mod alone...
