removing AFM on NB
16bit
Vehicle: NB8A - Supercharged
removing AFM on NB
Postby 16bit » Mon Jul 13, 2009 2:01 pm
Hello all I was wondering what would need to be done to be able to remove the AFM on my 98 nb. I have a piggy back computer (xede) which i would think would be able to handle it. Would I need another sensor of sorts? I would like to get rid of it for flow reasons mainly. Has anyone done this and if so how has driveability been effected if at all? Any help or advice would be greatly appreciated.
NMX516
removing AFM on NB
Postby NMX516 » Mon Jul 13, 2009 2:32 pm
You would need to use a MAP sensor instead, which will require after market ECU. The std afm causes three parts of f-all restriction, so unless you have a much better excuse for needing an after market ECU, save your dollars. :)
Juffa
removing AFM on NB
Postby Juffa » Mon Jul 13, 2009 2:37 pm
Damn...was too slow in typing.... what he said ^
16bit
removing AFM on NB
Postby 16bit » Mon Jul 13, 2009 3:07 pm
can't do it with xede i have found oh well.
removing AFM on NB
Postby manga_blue » Mon Jul 13, 2009 8:37 pm
NMX516 wrote:You would need to use a MAP sensor instead, which will require after market ECU. The std afm causes three parts of f-all restriction, so unless you have a much better excuse for needing an after market ECU, save your dollars. :)
So, does the NB8A MAF flow any better than the NA8 one? The NA8 one looks restrictive - it seems way smaller in area than the throttle body.
NMX516
removing AFM on NB
Postby NMX516 » Tue Jul 14, 2009 12:20 am
I'm fairly certain that the NA8 and NB ones are the same.
RG.net
removing AFM on NB
Postby RG.net » Tue Jul 14, 2009 4:03 pm
NMX516 wrote:I'm fairly certain that the NA8 and NB ones are the same.
Really? i thought they looked a little different =/
Steampunk
removing AFM on NB
Postby Steampunk » Tue Jul 14, 2009 4:24 pm
They are.
Inside the NA8 is a single column with a hole/cylinder in the centre that houses the wire-air temperature sensor.
Inside the NB's, they have a grid and I'm not sure where the temperature sensor is in there, but probably in the middle as well.
NMX516
removing AFM on NB
Postby NMX516 » Tue Jul 14, 2009 7:12 pm
Well there you go.... :) Lucky I wasn't 100% certain, only fairly certain :lol:
removing AFM on NB
Postby Regie » Sat Jul 25, 2009 4:35 pm
They are.
the NB temp sensor it attached to the airbox itself
AB7
removing AFM on NB
Postby AB7 » Sat Jul 25, 2009 6:24 pm
Yes, NB temp sensor is near the airbox. I got hydra EMS & moved mine closer to TB since I ditched the AFM.
