Water Pump WOOP WOOP
Techno
Postby Techno » Mon Sep 07, 2009 5:24 pm
It may be
1) When you replaced the big black tube that goes across the engine to the inlet manifold that you put it in slightly crooked and the resonator underneath is rubbing on the fan pulley. With the engine OFF, put your hand down the side of the black pipe below the inlet manifold and you should be able to get your fingers between the fan belt and the resonator box (part of but below the pipe).
2) The timing belt tensioner pulleys are shot
3) The fan belts need replacing ( try a little candle grease on them and see if stops ... or hit the underside of the belts with a shot of WF40)
4) If it is the hose between the back of the engine and the heater coil (two inlets mounted on the firewall, then replace it immediately ... you will get caught out somewhere on a dark and stormy night if you don't).
Hope this helps .... if not .... turn the radio up.
Rob
nick viner
Postby nick viner » Sat Sep 26, 2009 11:09 pm
Have you replaced the belt with a new one and if you have and it is "metal " filled it will make a woop noise.
I bought a new , expensive waterpump for my J 20 jeep , only to find it was the belt making the noise all the time
Users browsing this forum: No registered users and 31 guests
