Can anyone show pics of their oil cooler install?
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
I'm considering installing an oil cooler - just need some pis how others here (who have also done so) did their install.......
- Russellb
- RIP Nov 2014
Where I put mine in the clubman
also have the race car cooler in the same spot
My ClubmanRebuild
MX5 SE Rally car is HERE
- SuperMazdaKart
Not mine, nor is it an MX-5, but might provide some interesting ideas.
- Vehicle: NA8 - Turbo
Diff cooler or oil cooler on a 911?
- SuperMazdaKart
Hrm, custom radiator with integrated oil cooler on the side.
Haha, is actually a Familia GTR setup for rallying. I'd say it's most likely a rear diff oil cooler (though they don't usually need it).
http://www.rally24.com/rally-cars-for-sale/rally-car-2752.html
Adam_NAclubman wrote:Diff cooler or oil cooler on a 911?
- Benny
If you take off the front clip, you will see a big piece of white, honeycombed plastic.
Just mount it on the top of that and cut a couple of slots in the clip for fresh air to get in, just above the number plate.
Easy.
Easy.
- Uncle Arthur
Benny wrote:If you take off the front clip, you will see a big piece of white, honeycombed plastic.
Easy.
Let's just say for a moment I DON'T want to take a dremel the bodywork of my car......... although I do like the oil/radiator combo.
How much was that?
- fattima
This is what I did,
In the front panel there are some captive nuts already in place, made some alloy brackets that aligned with the holes and my oil cooler. Pretty simple to do.
Oil cooler lines run down side of radiator, I ground out then smoothed off the radiator side bracket to give clearance for the lines.
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
Nice! I like that one. Yours too Dave.
MX5 Wanted. SE or NC (forced induction preferred
where do you get the rad from or is it a custom job??
every ounce counts
- fattima
The cooler was on the car when I got it but was mounted differently. I believe it is a MX5parts UK one, don't ask me how much it weighs
Users browsing this forum: No registered users and 17 guests
