this might help:
viewtopic.php?f=44&t=36608&hilit=radiator+hoses
& don't forget our sponsors: http://www.mx5mania.com.au/product1533.htm
90 na 1.6 raddiator hose kit.
While you can just replace one hose, i.e. the one that is split chances are that the next weakest one will then split as well....
I can only suggest you replace them all. It may cost more in the short term, but it will be much cheaper than a worse case scenario of replacing the head, or engine if a hose completey splits and dumps all of the coolant. Try the forum sponsors or http://www.mx5parts.co.uk
J
ps I have also attached a copy of the NA coolant system, with part numbers.
J
