Gearbox piece on drain plug
Hen10
Postby Hen10 » Thu Apr 20, 2017 9:30 pm
Not exactly sure what to call it but when I was changing my transmission fluid today a piece of something was on the magnetic drain plug. Can anyone shed some light on what it could be? It's roughly one cm long and a couple of mm wide.
RS2000
Re: Gearbox piece on drain plug
Postby RS2000 » Thu Apr 20, 2017 10:08 pm
That looks like a synchroniser key (sometimes called synchroniser blocker bar). Usually 3 on each synchroniser hub/sleeve
Hen10
Postby Hen10 » Thu Apr 20, 2017 10:36 pm
RS2000 wrote:That looks like a synchroniser key (sometimes called synchroniser blocker bar). Usually 3 on each synchroniser hub/sleeve
I presume it's not ideal for the future longevity of my gearbox?
RS2000
Postby RS2000 » Fri Apr 21, 2017 9:50 am
I'll leave that call to a qualified transmission mechanic.
FYI see item 17-243 on attached image of MX5 5 speed gears.
IMG_5 speed MX5.pdf
Hen10
Postby Hen10 » Fri Apr 21, 2017 10:54 am
RS2000 wrote:I'll leave that call to a qualified transmission mechanic.
IMG_5 speed MX5.pdf
Had a chat to a mechanic friend this morning who said It's not ideal but to just keep driving it till it craps itself. Lucky 5 speeds are cheap!
