['90 NA] Proposed suspension setup
zephyrus17
Re: ['90 NA] Proposed suspension setup
Postby zephyrus17 » Sun Oct 16, 2011 1:56 pm
Yeah.. Plenty of choices. I'll probably just get the most value for money option. I just wished Australia had more options. and1, what are you running now?
Momo (aka 1990 white NA6)
tobias
Postby tobias » Sun Oct 16, 2011 2:30 pm
When I got the megans I couldn't understand why anyone else didn't have them! Where are you located?
tobias
Postby tobias » Sun Oct 16, 2011 2:31 pm
Ah just noticed your from Adelaide I was going to say you can take mine for a spin so you can see what there like
Wivvix
Postby Wivvix » Sun Oct 16, 2011 3:01 pm
zephyrus17 wrote:How about the FM V-Maxx? It's $695 for the NB conversion, and including shipping it'll be around $900 (haven't asked), which isn't too bad
From the sounds of things, they're fairly well made and well valved.
They're firmer than the Illumina's, but how much so is not totally clear.
NB conversion is $695, shipping is ~$330 @ 1.06AUD; so just north of $1000 landed.
There are some downsides to this set-up though.
No adjustable lower mount, so you lose travel by lowering (albeit not much).
No damper adjustment (putting a lot of faith in default damping).
Running similar spring rates to the BC BR. V-maxx (390lb/260lb or 7kg/5kg).
No pillow balls mounts included.
No local parts, spares, kits, replacement units, or warranty service.
Worth mentioning, the BC BR only come with pillowballs on the front. You can opt for pillowballs on the rear, or camber plates if so inclined.
Otherwise, as standard, the BR kits come with a rubber mount for the rear coilovers.
orangemx5 wrote:When I got the megans I couldn't understand why anyone else didn't have them! Where are you located?
On miata.net, people report about the Megan's having trouble with rear travel, amongst other problems.
zephyrus17
Postby zephyrus17 » Sun Oct 16, 2011 3:19 pm
@Wivvix, I get what you're saying. It's probably better to pay a bit more for the local BC BR due to the after sales support and the coil is 'better' itself.
@Orange, thanks for the offer! I'll surely look you up when I'm ready to make a decision. There's just the issue of saving enough cash (need new exhaust too), so it won't be too soon. But one can never research too much...
Postby NitroDann » Sun Oct 16, 2011 7:52 pm
Wivvix wrote:Worth mentioning, the BC BR only come with pillowballs on the front. You can opt for pillowballs on the rear, or camber plates if so inclined.
Hang on.
What?
Camber plates for an mx5.... They high?
plohl
Postby plohl » Sun Oct 16, 2011 8:37 pm
i second dann's comments.
Speak to justjap in sydney about the bc's. Pretty damn sure they have pillowball top mounts at both ends of the car. http://www.justjap.com/store/product.php?productid=19208&cat=&page=1
Other aus coilover options include yellowspeed racing from mx5 mania and HSD HR's from otomoto. You can cheaply get bilsteins from the states too, amongst many other options.
Note: none of the above coilovers are made in aus, just stocked by local distributors.
plohl
zephyrus17
Postby zephyrus17 » Sun Oct 16, 2011 11:19 pm
I'd get the FM kits in a heartbeat if not for the bloody shipping costs/import tax. That just makes the decision so much harder, because either way, it's still a large hunk of change.
Wivvix
Postby Wivvix » Sun Oct 16, 2011 11:57 pm
Hang on.
What?
You tell me I've seen a few mx5s with various set-ups and camber plates on the front. Go figure.
BC Racing do make several different sub-models of the BR series. RA, RS, are the most common.
plohl wrote:i second dann's comments.
Also worth noting those BC BR are 8/6, not 7/6. You can however order whatever spring rate you want (takes 2 weeks).
plohl
Postby plohl » Mon Oct 17, 2011 1:59 am
camber plates dont change the chamber on an mx5's.....
plohl
Wivvix
Postby Wivvix » Mon Oct 17, 2011 9:12 am
plohl wrote:camber plates dont change the chamber on an mx5's.....
Hence...
Wivvix wrote: or camber plates if so inclined.
Postby NitroDann » Mon Oct 17, 2011 9:51 am
Im about to import and sell some cam shaft kits for mx5s, also comes with upgraded pushrods if so inclined.
plohl
Postby plohl » Mon Oct 17, 2011 10:47 am
^ gold! hahahahahahaha
is the if so inclined comment a pun? If so, it should be noted with [pun]****[/pun]
plohl
Postby NitroDann » Mon Oct 17, 2011 12:15 pm
Lol thanks.
zephyrus17
Postby zephyrus17 » Tue Oct 25, 2011 1:23 pm
I've also been made aware of the HSD HR Coilovers, they're very popular with the drift scene and designed for the track, but not much in terms of the MX-5. Does anyone have any personal experiences? And being a 9/6, would they be too hard for the road?
