Rear sway bar clamps
greenman
Re: Rear sway bar clamps
Postby greenman » Tue Nov 01, 2011 8:27 pm
Awesome clamps and service.
Did they recommend the mounting position?
As in closer together on the mounts, or apart, on the outer side of the swaybar mounts.
Hard to describe, sorry
mitch_f1
Postby mitch_f1 » Tue Nov 01, 2011 8:32 pm
Yeh, I know what you mean. Ideally they would go inside of the bush, but can also go outside of the bush, either way they need to be sitting right up snug next to it, otherwise it is till going to allow movement in the sway bar. The subframe stops me doing this, as I think you can kind of see in the pics on page 1
greenman
Postby greenman » Tue Nov 01, 2011 8:34 pm
What about getting HD mounts?
Do they make them for MX5s?
Maybe they would give you more clearance?
mitch_f1
Postby mitch_f1 » Tue Nov 01, 2011 8:38 pm
Explain these HD mounts please?
greenman
Postby greenman » Tue Nov 01, 2011 8:44 pm
Here's a link to whitelines site.
http://www.whiteline.com.au/docs/bullet ... _kbr20.pdf
I know it's for Subaru.... Hence my comment asking if they make them for MX 5s.
EDIT
Check here too. Sorry I'm on an iPhone.
http://www.whiteline.com.au/do_segue4.p ... ehicle=ALL
Perhaps it's a question Whiteline can answer.
mitch_f1
Postby mitch_f1 » Tue Nov 01, 2011 9:06 pm
Probably not going to work as I do not think that there is enough room. I also made me think I could use a spacer to space out the bracket from the subframe, but the bolts aren't long enough.
greenman
Postby greenman » Tue Nov 01, 2011 9:09 pm
A washer, collar, shim, spacer, could do the trick.
As you say, provided you use longer bolts.
I'll make some calls tomorrow.
mitch_f1
Postby mitch_f1 » Tue Nov 01, 2011 9:17 pm
So this is a photo of the actual ones I got
I am going to try taking a few mm off of the bottom of one side, and see what happens.
Thanks very much for your help greenman
greenman
Postby greenman » Tue Nov 01, 2011 9:19 pm
Glad Whiteline sent you those ones rather than the press fitting fail ones. :mrgreen:
