Recurring Brake Issue
DaveWA
Vehicle: 10AE
Postby DaveWA » Fri May 06, 2011 4:13 pm
I have an issue with my brakes
1999 NB 10 AE
I put new carbotech pads all round 3 months ago
all ok until brakes began to feel that they were not releasing completely
adjusted rears all OK after 2 3 weeks, same issue has reoccured
starts off ok ends up feeling like I have 100 kgs extra in the boot
So far I have greased the slider pins and thoroughly flushed the brakes
any thoughts as to why this is happening
Re: Recurring Brake Issue
Postby Okibi » Fri May 06, 2011 5:18 pm
Sorry can't think of an obvious reason unless it's a dodgy master cylinder, with the rears are you tightening the adjustment screw and then loosening it 1/3rd of a turn?
Postby manga_blue » Fri May 06, 2011 6:45 pm
Have you had a look at this thread? http://mx5cartalk.com/forum/viewtopic.php?f=30&t=46321
NMX516
Postby NMX516 » Fri May 06, 2011 7:00 pm
I recently had a similar problem, turned out that one of the front calipers had some corrosion in it. Had the two fronts rebuilt, problem solved.
DaveWA
Vehicle: 10AE
Postby DaveWA » Sat May 07, 2011 12:05 pm
thanks guys
looks like i have a bit of work in front of me
will let you know how i go
DaveWA
Vehicle: 10AE
Postby DaveWA » Fri Aug 26, 2011 12:02 am
replaced the brake booster
issue solved
geofiz
Postby geofiz » Fri Aug 26, 2011 1:08 am
Dave,
Glad to hear it is finally fixed. Was it the booster or the little rubber 'reaction disc' that goes between the pushrods from booster to M/C?
NB8A - mostly stock for now
DaveWA
Vehicle: 10AE
Postby DaveWA » Sat Aug 27, 2011 1:04 pm
It was the Booster
Just working out some vacuum issues
And then I'll be back at the track
Work and family engements permitting
