Custom wheel adaptors
Posted: Sun Aug 14, 2011 12:01 pm
by red devil
If anyone is interested iv found a company that makes custom wheel adaptors, which allow you to choose size, a new bolt pattern etc
http://www.motorsport-tech.com/wheel_adapters.html
Thought I should share
Cheers eren
Re: Custom wheel adaptors
Posted: Sun Aug 14, 2011 1:33 pm
by Steampunk
These are everywhere. Same theory for/against wheel spacers.
Posted: Fri Aug 19, 2011 7:21 am
by Patrick Bramston
I need to run 17's to fit over my AP 330 mm disks and would like to run 17x9's with 235/40/17 semi slicks and have thought about wheel adapters.. Is the only problem that they act like spacers. I am thinking of running 15x10 on the back with 250/585/15 slicks and using my current 215/45/17 slicks on the front. Seems a bit odd having 2 inch smaller wheels on the back but it gives me 35mm more tyre on the back as wheel spin out of corners is a big issue with 180rwkw and 700 torques. ...
ANY THOUGHTS ?? Patrick
Posted: Fri Aug 19, 2011 9:35 am
by project.r.racing
plate style spacers and bolt on adaptors are 2 very different things.
Posted: Fri Aug 19, 2011 9:52 am
by 16bit
just get special order work emotion 11r in your psd. easy as pie.
Posted: Fri Aug 19, 2011 11:47 am
by NitroDann
Some dont want to spend thousads on wheels when 6ULs are just as good and very cheap.
Im sure patrick is included.
Posted: Fri Aug 19, 2011 5:01 pm
by Patrick Bramston
HELP PLEASE..Where is the best place to buy the work Emotion 11r. Japan/USA/other .They seem to have 17x9 in +17,+28 and +38 in PCD 4x100 .What offset will go with coilovers and rolled guards..I think the offet on 15x10 6ul's is +25..thanks Patrick
Posted: Fri Aug 19, 2011 8:11 pm
by NitroDann
Lol,
Ill shut up now..
Posted: Fri Aug 19, 2011 8:24 pm
by Patrick Bramston
I only want 2 for the rear, much better to have 17's with 245/40's..come on Dan wher can I get them from?? Somewhere that doesn't charge $500 for freight..PB
Posted: Fri Aug 19, 2011 11:40 pm
by deviant
Cant you talk to someone like http://www.metalspinnersaust.com.au/met ... pgodEGtX8Q or maybe see who is doing Simmons wheels these days. For a very specialised application it is worth getting the right thing for the right job and getting a set made to suit...it will be safe and it will be money well spent as it will work!
Posted: Sat Aug 20, 2011 8:51 am
by project.r.racing
deviant wrote:Cant you talk to someone like http://www.metalspinnersaust.com.au/met ... pgodEGtX8Q or maybe see who is doing Simmons wheels these days. For a very specialised application it is worth getting the right thing for the right job and getting a set made to suit...it will be safe and it will be money well spent as it will work!
wheel Warehouse in Brisbane brought most of Simmons old manufacturering gear. They still do custom sizing in 15s and 17s only.
Posted: Sat Aug 20, 2011 5:38 pm
by Patrick Bramston
I am going to find out Monday about changing the rear hubs to 5x114.3. Then 17x9's are a time a dozen. Patrick
Posted: Sun Aug 21, 2011 11:10 am
by red devil
Nice let me know how Pat!
Im looking to upgrade my hubs as well as i want to run bigger bearings in the hubs so i can get the engineer to sign off on my new wheels
Cheers eren
