What brakes should I get
Posted: Wed Oct 05, 2011 9:28 pm
by olboy
Hi
I have a an unregistered NA6 that I use for track days and hillclimbs
I have just fitted a turbo setup and a torsen
I have done the suspension suspension and braces etc
Now I'm up to the brakes but I'm running out of money fast
I liked the look of wilwoods but with the dollar the way it is they are getting dearer by the day
Can anyone recomend anything else
PS I have 15 inch rims
Re: What brakes should I get
Posted: Thu Oct 06, 2011 8:42 am
by Boyracer
I have a set of NB8B brakes for sale in Sydney.
Posted: Thu Oct 06, 2011 11:05 am
by olboy
PM sent
Posted: Thu Oct 06, 2011 11:26 am
by 93_Clubman
olboy wrote:PS I have 15 inch rims
Not all 15" rims will fit NB8B=>
But NB8A 15" rims will.
Posted: Thu Oct 06, 2011 3:54 pm
by Regie
have a look at the yellowspeed brake kits from mania
Posted: Thu Oct 06, 2011 8:05 pm
by olboy
I'm sure the yellowspeed are very good but the wilwoods cost alot less
I would like to keep it under $800
Boyracer has some NB8Bs for $800 but they are second hand and will probably need pads
Wilwoods are going to cost a little over $900 brand new with pads but thats only the fronts
I'm leaning towards the wilwoods
olboy
Posted: Thu Oct 06, 2011 9:42 pm
by plohl
spend less on brake upgrade, more on good pads
:beer:
Posted: Fri Oct 07, 2011 6:34 am
by olboy
So whats better bang for buck
nb8a front and rear $450 + pads $500 = $950
nb8b Front and rear $800 + pads $500 = $1300
Wilwoods $820 + prop valve $70 + Rear upgrade ?( i already have very good pads with std brakes ) = $890 + maybe upgrade
looking forward to any replies
olboy
Posted: Fri Oct 07, 2011 7:30 am
by hamx5ter
olboy wrote:So whats better bang for buck
olboy
Best bang for your buck... nb8b f&R...
If you are spending money to upgrade brakes, I wouldn't waste it on upgrading to nb8a, go with nb8b or the willwoods. The nb8bs are still single-piston calipers vs. the willwoods 4 pots though, something to consider.
Posted: Fri Oct 07, 2011 8:57 am
by MINX
Open to offers on my SE Front brakes
http://mx5cartalk.com/forum/viewtopic.php?f=44&t=48893
Havent tested the Wilwoods on circuit yet(only Hill Climb) but on road- they are good, but i suspect a pad upgrade may have felt just as good.
The SE brakes are a good thing for most drivers, particularly with more aggressive pads for track work.
Wilwoods look nice :D
Posted: Sun Oct 09, 2011 3:14 pm
by olboy
Anyone know where to buy wilwood stuff in Australia
Olboy
Posted: Sun Oct 09, 2011 7:38 pm
by olboy
What your setup and how do you like it
Posted: Mon Oct 10, 2011 2:40 pm
by 16bit
Posted: Tue Oct 11, 2011 3:39 pm
by Apu
Sorry for the hijack but NB8B/C brakes are the same as the SE brakes, correct?
Posted: Tue Oct 11, 2011 7:05 pm
by PeterB
On Fanta (ex Brian Anderson NA6 lightweight race car I used for supersprints - Wakefield 1.09.25 with n/a 1600) I used
Front NB8A front diameter slotted rotors with Willwood calipers and Willwood A compound pads
Rear NA6 front diameter slotted rotors with Outlaw calipers (similar to Willwood) and Willwood Q compound pads
No handbrake
No brake booster, Mazda master cylinder
Willwood bias adjuster in cabin
15x8" rims
I found this a very effective setup and the Willwood calipers are very easy to change pads on using the locating pins (easier than Mazda calipers).
