Re: Vibration and rattling
Posted: Tue Dec 06, 2011 1:12 pm
by 93_Clubman
im_boostn wrote:I can see the passenger seat shaking and the seat doesn't seem to be loose.
You can rule in or out the passenger seat by moving the seat base back (if necessary) & then reclining the seatback so that it's pressing against the rear bulkhead. That will at least stop it shaking & might allow you to better identify where the issue originates from.
Posted: Tue Dec 06, 2011 3:54 pm
by Regie
worn shock possibly
Posted: Tue Dec 06, 2011 4:27 pm
by RJ45
Check your wheel nuts are all there & that none are loose.
Looks like someone was halfway through trying to borrow one of my rear wheels.
After replacing the 2 missing nuts, things felt better.
Posted: Wed Dec 07, 2011 1:52 pm
by Locutus
are you sticking the passenger seat belt tongue into it's holder in the trim when it's not in use?
Posted: Wed Dec 07, 2011 3:07 pm
by Charlie Brown
Forget the rattle that's caused by the vibration.
Check your rims aren't warped or the tyres flat spotted.
Posted: Fri Dec 09, 2011 3:01 pm
by ak_perth
Sounds a bit like wheels are not balanced? Maybe a balancing weight has fallen off perhaps? You could take it to a garage so they can check the balance?
Posted: Tue Dec 20, 2011 6:27 am
by RJ45
Is it just a rattle or does it feel like the suspension is crashing badly over every little bump/join in the road that isn't smooth?
