Rear calliper piston not winding in
Posted: Sun Mar 08, 2015 2:57 pm
by lowwn
Today I decided to install new pads and rotors for the rears and the fronts but when I went to do the rears, turning the allen key didn't pull the piston back or even push it forward enough for the pads to touch the rotor. New calliper? could I rebuild it? can I just replace that thread somehow?
Re: Rear calliper piston not winding in
Posted: Sun Mar 08, 2015 4:23 pm
by project.r.racing
is the bleed valve open?
Posted: Sun Mar 08, 2015 7:22 pm
by lowwn
I fixed the problem. Just winded the grub screw all the way out then used a c clamp and the old brake pads to very carefully push the piston back in then winded the grub screw back in and the mechanism works perfectly now.
Posted: Sun Mar 08, 2015 7:31 pm
by aka_juffa
Did you check the slide pin on the rear brake in question ? If not maintained correctly the slide pin can corrode and cause the problem as reported. Using the G clamp may have been enough to free it. You should check all of the slide pins at least once a year and use an appropriate lubricant. A small sachet can be bought at Super Cheap and will last for some the.
J
Posted: Sun Mar 08, 2015 9:06 pm
by lowwn
The side that I had this problem with was also a bit harder to take the slide pin out which could have caused the problem. I greased it with what came with my pads and ill inspect the slide pin next weekend, thanks
Posted: Mon Mar 09, 2015 10:06 am
by 93_Clubman
Also, on RHD NA, the rear passenger side adjuster tends to be the first to start siezing:
http://www.miata.net/garage/ebrake/index.html
