ND new car alignment?
OMY005
Postby OMY005 » Wed Aug 03, 2016 4:49 pm
G'day, Should I be thinking about having the wheel alignment checked on my car after I pick it up? The big forum seems to think so, as the factory spec tolerances are quite large.
I'll be doing less than 5K a year so having more aggressive settings would not concern with issues about tire wear.
Fulcrum suspension is very close to where I live so I'd be going there unless there is some other suggestions?
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
JBT
Re: ND new car alignment?
Postby JBT » Wed Aug 03, 2016 6:26 pm
Probably best to drive it in varying conditions for a while to see if there are any indications that things could do with a reset.
OMY005
Postby OMY005 » Wed Aug 03, 2016 7:06 pm
I dropped into fulcrum on the way home today, $35 to have it checked out. I might do that and then drive it for a while like mentioned above.
Thanks, Andrew.
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
project.r.racing
Postby project.r.racing » Thu Aug 04, 2016 2:02 pm
All new modern cars have a larger variance in their alignment settings. Have you done so in other new car purchases?
OMY005
Postby OMY005 » Thu Aug 04, 2016 2:14 pm
project.r.racing wrote: Have you done so in other new car purchases?
No, I've never had a brand new car before. :mrgreen:
Andrew
pcmx5
Postby pcmx5 » Thu Aug 04, 2016 4:27 pm
I have a friend with a 2ltr and his factory alignment was so bad that he took it to a local shop and every corner was way out! Mine was a demo and seems ok but I am putting Eibachs on it and will be going for a more aggressive alignment after that.Many posters on the big forum complaining about new car alignment so $35 well spent in your case I would think.
Peter.
OMY005
Postby OMY005 » Mon Aug 08, 2016 1:08 pm
I picked up the car on Friday, going to get an alignment check this afternoon, will post up the findings and go from there to see if anything needs to be changed.
Andrew.
OMY005
Postby OMY005 » Mon Aug 08, 2016 8:27 pm
Here is the before and after from this afternoons alignment check and adjustment. Thanks to the guys at Fulcrum.
Andrew.
JBT
Postby JBT » Mon Aug 08, 2016 9:20 pm
Seems like a lot of toe in on the rear Andrew. I would have thought about 2mm would be right...
OMY005
Postby OMY005 » Mon Aug 08, 2016 9:57 pm
I'm not really sure of the range it should be? The figures are what they recommended and said something about static and dynamic settings. Open to suggestions though.
Andrew.
pcmx5
Postby pcmx5 » Mon Aug 08, 2016 10:13 pm
Andrew may be worth a visit to Miatanet to see the alternatives,some interesting settings including some from BARWON an Australian member down here in Geelong.A LOT different to yours particularly toe @ 1/32 in.
Peter.
RS2000
Postby RS2000 » Mon Aug 08, 2016 11:40 pm
OMY005 wrote:I'm not really sure of the range it should be?
The factory range is shown on your chart as +3.6mm /+4.7 -4.7 which is from +8.3mm to -1.1mm (you are near the mid point at +3.9mm)
I thought this must have been a misprint, until I looked up the factory specs for my NB8a. It shows +7mm to -1mm both front & rear.
I'm surprised!
project.r.racing
Postby project.r.racing » Tue Aug 09, 2016 7:44 pm
Wowzers! The settings were way out.
OMY005
Postby OMY005 » Tue Aug 09, 2016 8:37 pm
I guess it would be hard for manufactures to get them much closer to ideal as the cars go down the line? And also, most drivers of other cars don't know or care if the setting are out a bit, wear being more important than handling?
Seems like money well spent then.
Andrew.
RS2000
Postby RS2000 » Tue Aug 09, 2016 9:40 pm
There is bugger all difference between before & after, & both are within factory spec. The biggest change was adding 1mm to rear toe in.
