Engine Diagnostic Codes 99 NB
Posted: Sun May 29, 2016 11:27 pm
by tiw
G'Day All,
Tried pulling the codes from my 99 NB with a LED and I appear to have received the following:
10, 14, 14 and 13.
Does anyknow why it would be throwing the same code twice?
Does anyone know if the codes I have found below are correct for an NB?
Code Meaning
1 Ignition pulse
2 Ne signal
3 G signal
4 SGT signal (1.8L)
8 Airflow meter
9 Water thermistor
10 Intake air thermistor in airflow meter
12 Throttle position sensor
14 Atmospheric pressure sensor
15 Oxygen sensor (output too low)
16 EGR function sensor (1.8L)
17 Oxygen sensor (output not changing)
25 PRC solenoid valve (1.8L)
26 Solenoid valve (Evaporative canister purge)
27 EGR solenoid valve (vacuum)(1.8L)
28 EGR solenoid valve (vent)(1.8L)
34 34 Idle air control (1.8L)
36 Idle speed control valve
Thanks
Re: Engine Diagnostic Codes 99 NB
Posted: Mon May 30, 2016 12:36 pm
by 93_Clubman
Codes get stored in ECU unless battery disconnected, so it probably just thrown that code at two different times. Probably best to disconnect battery, pump brake pedal a few times, reconnect battery, drive, & check codes again. Codes should be in the NB8A (1998-2000) manual here:
viewtopic.php?f=76&t=37363
Posted: Mon May 30, 2016 12:45 pm
by tiw
Brilliant, thanks
