My era of MX5 ownership! Twilight Blue NB8A
Ando
Postby Ando » Thu Apr 09, 2009 10:23 am
[quote="hks_kansei"]new number plates arrived today.
POP plates, reprint of standard issue but in slimline and black.
Are these after market plates? I have the bog standard yellow NSW plates on mine and the RTA said I would have to change my rego # to get white or black and pay an annual fee.
I'm not a fan of the yellow but I used to pay $160 a year for my old custom euro plates and I don't want to go there either. Maybe I could paint them?? :shock:
Ando
~ 1999 Twilight Blue NB8A ~
1として馬そしてライダー
philz
Wheel guru
Postby philz » Thu Apr 09, 2009 10:47 am
In NSW if you want the same numbers from your yellow plates onto white plates it will cost you an annual fee. (yes it's farking weird i know)
However if just want white plates, it will cost you only $70 bucks upfront, but you will need to change rego as well, but that's easy.
Postby hks_kansei » Thu Apr 09, 2009 11:42 am
no, mine arent aftermarket plates.
in Vic you can contact Vicroads and order new plates in any colour, it was $11.50 per plate for slimline, and $99 for a colour, one off cost.
in NSW I think personalised and colours require an annual fee to be paid?
also, you cant legally just paint the plates yourself.
Amanda
Postby Amanda » Sat Apr 11, 2009 5:26 pm
hks_kansei wrote:in Vic you can contact Vicroads and order new plates in any colour, it was $11.50 per plate for slimline, and $99 for a colour, one off cost.
Hi HKS
Can you do that over the Internet or Phone? My car would look heaps better with those black plates :lol:
fattima
Postby fattima » Sat Apr 11, 2009 6:12 pm
You can do it person at Vicroads or over the net, called POP plates
http://www.vplates.com.au/pop-plates/
I ordered a set for mine when I registered the new beast, took less than a week to arrive. I reckon they would look great on your car Amanda.
Postby hks_kansei » Mon Apr 13, 2009 12:20 am
yeah, I did mine over the net, arrived within a couple of weeks.
and the bonus of not having to deal with the local Vicroads office! :P
oh, also made an extinguisher bracket today.
bit of Bunnings Galvanised steel plate thing ($1.60) drill a couple of holes same size/distance as seat rail bolts, spray satin black, attach extinguisher cradle thing, done.
CheyneX5
Postby CheyneX5 » Mon Apr 13, 2009 1:17 am
nice man, i have been wanting to do this for a while now...
90' NA6 - Classic Red
Postby hks_kansei » Mon Apr 13, 2009 1:31 am
the extinguisher mount is very simple to do and not expensive.
CAMS approved 1kg extinguisher and bracket <$30 from Supercheap auto
galvanised nail plate from bunnings $1.60
seat bolts require a 10mm hole.
if you like I could trace out a template and post it up here?
Postby hks_kansei » Sat May 16, 2009 3:05 pm
just finished another addition, this one came out of pure necessity.
because the number plate hangs out in front of the car, this makes it easy for people to walk into and bend my number plate and make it look shitty. I learned this after one day hearing a clunk from the garage and then a large amount of swearing from my dad.
anyway, after straightening the plate I decided it needed some re-enforcement so that this time, the plate is safe. Legs will heal, my car wont. :P
anyway I've had the bits around for ages and today just plucked up the effort to do it.
here's pics.
looks normal from teh front.
is thicker from the top
and looks ghetto on teh back, but thats no issue since you cant really see this bit anyway.
so yeah, after this, teh result is the plate is good and rigid and will take a heap to bend.
Postby Mr Morlock » Sat May 16, 2009 4:26 pm
It does not need to hang out in front- with slimlines and some adjustment to brackets the plate can be mounted in the "mouth" -grille opening. It seems there is plenty of air flow around the slimline and I have not noticed any cooling impediment.
rascal
Postby rascal » Tue May 19, 2009 4:31 pm
hks_kansei wrote:the extinguisher mount is very simple to do and not expensive.
Do you have any pics of the extinguisher bracket?
Sounds like a good way to mount mine...
Postby hks_kansei » Tue May 19, 2009 11:51 pm
I only have one photo, and it's not the best (taken while the paint was drying)
anyway, here it is.
I forget the size of the Gal plate, but there was one in bunnings that was about right, I think 380mm by 150mm sounds familiar?
but the total cost was:
1kg fire extingusher with CAMS approved bracket $35 from Super Cheap Auto
rectangle nailing plate $1.60 from Bunnings
satin black paint $2 (I had a can lying around anyway)
random screws for attaching extinguisher bracket to the plate $free (found them on the bench)
the bolt holes for the seat rails are 10mm diameter, you need a 14mm spanner/socket to remove them.
just remember to measure twice, cut once (or drill once)
also be aware that you need to allow for the extinguisher, mine sits a little too close to the seat and the ext touches the corner of teh seat rail, no problem, but it scratched some paint off the extinguisher.
rascal
Postby rascal » Wed May 20, 2009 10:09 am
I presume this is mounted in front of the passenger seat?
Did you bolt the plate between the seat and the rails so it moves with the seat adjuster?
Any pics of it in the car?
Tks
Rus
Postby hks_kansei » Wed May 20, 2009 6:10 pm
rascal wrote:I presume this is mounted in front of the passenger seat?
correct, sits just in front of the passenger seat.
rascal wrote:Did you bolt the plate between the seat and the rails so it moves with the seat adjuster?
no, the plate is underneath the rail, it is sandwiched between the seat rail and the floor,so you can no longer move the seat fore and aft, however because it is using existing bolts you can easily remove the extinguisher in about 5mins.
I shall try and get some pics of it installed soon.
Postby hks_kansei » Thu May 21, 2009 11:14 pm
as requested, pics of it in teh car.
Image Image Image
and a closeup of how it's attached.
Image Image
see how the matte black plate is between the carpet and the seat rail.
