ManiacLachy wrote:Lokiel wrote:If you don't have them already, I can lend you my carbide bit set.
Where did you find carbide bits to fit the dremel? I couldn't find any a while back when enlarging the holes on my seat brackets. I could only find ones that would fit a drill, worked well on stainless steal but might be a bit overkill for the delicate work on an aluminium manifold.
eBay of course, search for "10x Solid Carbide Burrs For Dremel Rotary Tool Drill Die Grinder Carving Bit" kit and you'll get lots of hits:
Also ordered some flapper wheels but didn't end up using them after reading about FM's issues with them.
Photo also shows my grinding stones I'd used in the past on aluminium, which is why I ordered the carbide bits.
Here's my final effort:
That section from 0000 to 0200 in the photo, just above the notch, is where I would have liked to take off more material but the neck is too thin in that arc, I've just removed material from the flange, otherwise I'm happy with the port, even though it's not shiny-smooth.
More details can be found in my garage thread starting at
https://mx5cartalk.com/forum/viewtopic.php?f=57&t=76716&start=98, there's some casting burrs inside the manifold that can be removed and I also improved flow out of the rear runner.
