Page 1 of 4
NitroDann's K24 swap build thread.
Posted: Wed Nov 20, 2013 3:32 pm
by NitroDann
Post reserved for final details.
Gossip away. :twisted:
Re: NitroDann's K24 swap build thread.
Posted: Wed Nov 20, 2013 3:38 pm
by 16bit
dude, i was just looking at euro engines and thought 'how much would dann charge'?!!!!!!!!!!!!!!
Posted: Wed Nov 20, 2013 3:49 pm
by NitroDann
Posted: Wed Nov 20, 2013 4:00 pm
by PaulF
I'm going to be pretty mad if this isn't what you're implying it is.
Posted: Wed Nov 20, 2013 4:15 pm
by 16bit
why do i get the feeling this is not going into something that has an mx5 'body'?
Posted: Wed Nov 20, 2013 4:25 pm
by NitroDann
Nope, NA6 chassis, currently 200whp boosted, going to 200whpish n/a Honda K24 engine.
With potential for 500whp later.
Posted: Wed Nov 20, 2013 4:56 pm
by plohl
ƒü¢k you dann :P
What are you doing re subframe/steering geometry? Butchering a stock one or going down the v8 roadster path? You know the rack mounts are different between RH and LH drive right? The build on k20a.org looks like the butchered sump/bottom of the engine could be really freaking close to the steering rack column. Which is a perfect segway...
What are you going to do re the oil system? I have noticed on magic's build that it looks like they machined a new inlet manifold for the oil pump so they could make the plumbing to the pick up fit. They're also using a different oil pump from a type s (assume integra/k20a*) as the k24 one has balance shafts.
What k24 are you using? A k24a3 from an adm accord euro?
Is the plan to get a flywheel, adapter plates etc from Magic in the states? Or are you looking to get stuff made here?
This could be the catalyst...
Posted: Wed Nov 20, 2013 4:59 pm
by 16bit
thought it was going to be a exocet k24.
Posted: Wed Nov 20, 2013 5:17 pm
by sailaholic
Sub-fking-scribed. +1 to everything Plohl said plus hurry the fk up and make sure you price in shipping of two sets of parts to QLD.
Personally I'm just as interested in a k20 to say in 2l classes.
Posted: Wed Nov 20, 2013 6:33 pm
by slug_dub
You're such a damn tease. You know you'd get way more serious props if you did it in secret and then launched it all on us unawares... blowin your load too early haha!
p.s. get it done niaow!
Posted: Wed Nov 20, 2013 10:22 pm
by Jeo
Presumably relatively straight forward to get legal too?
Posted: Wed Nov 20, 2013 10:46 pm
by sailaholic
Jeo wrote:Presumably relatively straight forward to get legal too?
Legalities are likely to be the easiest part.
Posted: Thu Nov 21, 2013 10:45 am
by charlie_91
This is what i was planning for 2014. Kudos
Look forward to seeing updates
Posted: Thu Nov 21, 2013 11:17 am
by TTT
what gearbag will you use?
Posted: Thu Nov 21, 2013 1:39 pm
by sailaholic
The swaps in the states are retaining the mx5 box so as to retain the ppf etc.
