Page 1 of 8
December club track day
Posted: Sat Oct 04, 2014 8:09 am
by Regie
Should be a good one. Sent my entry off yesterday
Re: December club track day
Posted: Sat Oct 04, 2014 5:48 pm
by Guran
I'm entered too. 8)
The 86/BRZ Club have been invited to enter so there's an extra incentive to come along and show them what a proper sports car can do!
Posted: Sat Oct 04, 2014 7:03 pm
by manga_blue
Guran wrote:I'm entered too. 8)
Barge alert! :D Maybe David could add the following instructions to Toyota drivers at the briefing: "If you see an MX5 approaching you then pull carefully off the racing line, point to the side that you wish the MX5 to overtake you and tug your forelock as it passes."
Posted: Mon Oct 06, 2014 3:24 pm
by Apu
Entered!
Posted: Mon Oct 06, 2014 4:20 pm
by david_syd_au
manga_blue wrote:Barge alert! :D Maybe David could add the following instructions to Toyota drivers at the briefing: "If you see an MX5 approaching you then pull carefully off the racing line, point to the side that you wish the MX5 to overtake you and tug your forelock as it passes."
Happy to oblige, although that won't work for the baldies unfortunately. No forelocks :-)
Posted: Thu Oct 09, 2014 10:36 am
by zossy1
I've entered - will bring the blue rocket if it is back together and survives the AASA Titles. Otherwise the black NB8B may make a debut...
Posted: Thu Oct 09, 2014 12:49 pm
by mazmad
Consecutive weekends Chris, nice!
Posted: Thu Oct 09, 2014 2:16 pm
by zossy1
Yep... Pulling the engine over summer for a rebuild so it will be a final fling for the existing engine :)
Or... A debut for the black car?
Posted: Thu Oct 09, 2014 4:36 pm
by manga_blue
Glad you're entered, Chris. Now I'll have to think about what parts I might need from you. :)
Posted: Thu Oct 30, 2014 9:41 pm
by PeterB
I am entered and will be running my new Evo Gold NB8A in the clubman class.
I have fitted the Torsen 2 from Britney and refitted a standard exhaust from Helen's green NB8A. I have also transferred the Brown-Davis and Sparco V with 6 point harness from the NA
I will ask for a ruling on the day to see if the cosmetic body kit (side skirts, lip spoiler and boot ducktail) rate as an aero modification or if it is cosmetic, as it is not easily removable.
A couple of questions for Bryan or Gus ;
Brake pads - what are you using in the NB - Hawk HP+ or something else. If so do you run them on the street as well or swap for the track day.
Tyres - I have some 15X6.5" rims with 205x50x15 Kumho KU36 - these seem to fit within the rules, but can anyone confirm if that is the case. If not I will bring some semis and run modified this time until I get eligible tyres.
thanks
Posted: Thu Oct 30, 2014 10:46 pm
by guss
PeterB wrote:A couple of questions for Bryan or Gus ;
thanks
Good to know there will be more competition in the clubman class.
I had Hawk HP+ before, now I'm running Hawk Blue on the front. Always had standard pads on the rear. The Hawks produce an awful amount of brake dust, but other than that are still quite good on the road, although apart from the odd drive to the shops with the roof down, my MX5 is almost exclusively for the track.
Not sure about the KU36's. I think they may be deemed as semis, better check with Mike first.
Posted: Fri Oct 31, 2014 7:18 am
by Guran
Peter, KU36 are classed as road tyres in the Vic rules which are the basis for our class 4. You'll be fine with using them in class 4.
I've been using whatever brake pads were in my 10AE when I bought it. I think they were Bendix Ultimate on front and Green Stuff on rear. Pretty ordinary though and I was having lots of lock ups on the rears. I've just fitted a set of Hawk Blue all round on new rotors. They felt much better at Marulan last Sunday. Lots of sparks apparently and I got them hot enough to burn off the blue paint!
Posted: Fri Oct 31, 2014 12:08 pm
by mx5002
Sent my entry in :)
Posted: Tue Nov 04, 2014 10:32 am
by yem11n
yay... entered and paid today. though I have been to this track a few times this will be my first with MX5 club..
I'm slow so will need to learn from other drivers.. :lol:
Posted: Tue Nov 04, 2014 11:56 am
by badface
Spot confirmed! Already can't wait. Will probably head down the night before and camp in Goulburn instead of waking up with the sparrows on the day. plan on getting some Eccentric bushes up the front and getting a bit more camber dialed in.
