My thoughts on LEGAL Turbo engineering (NSW BASED)
Technical Guidance for doing those Tricky Jobs
Re: My thoughts on LEGAL Turbo engineering (NSW BASED)
Postby NitroDann » Tue Jun 19, 2012 11:55 pm
Yep its flocked.
Sean
Postby Sean » Sun Jun 24, 2012 10:07 pm
Hjt wrote:I'm looking to get seats and roll bar engineered. They would obviously meet the compliant ADRs, would the engineering costs be very high?
Chances are you won't find an engineer willing to certify the bar anyhow.
Tell Mt plod it's a style bar not a roll bar -that way it doesn't require certification - Not sure on measurements but a style bar also wont require padding.
VroomVroomBlackSheep
Postby VroomVroomBlackSheep » Mon Dec 16, 2013 12:28 am
NSW RMS\RTA has again changed there car modification scheme in October this year (2013).
Does anyone know what is required now for a turbo conversion on a NA8?
-Engineer Cert?
-Brake test on air strip or possible upgrade?
-Emissions test?
-All the above?
It looks to have changed significantly.
Also reintroduced small engine size increases from same family with just blue slip. Think they removed it at one stage.
Any help is appreciated.
Sean
Postby Sean » Mon Dec 16, 2013 1:14 am
VroomVroomBlackSheep wrote:NSW RMS\RTA has again changed there car modification scheme in October this year (2013).
-Engineer Cert?
-Emissions test?
-All the above?
Based on cars passed since the new scheme, my understanding:
Engineers cert - YES
Brake test or Upgrade - Engineer to advise based on other mods, I've seen cars pass the new scheme going from NA to FI without a brake upgrade.
Emissions test - YES is the starting point, although there are some exclusions. It's pretty easy to pass these days with E85.
Admittedly I haven't seen an NA/NB go through the new system, only NC SC and non MX5s.
Best bet would be to call an engineering signatory (RMS will give you a list). Don't bother with the RMS technical line, they will give you a different answer each time you call.
Postby VroomVroomBlackSheep » Mon Dec 16, 2013 10:56 am
Thanks mate..
I have spoken to RMS. Basically beat me around the bush and gave me a bunch of hoohaa.
Thanks.. now just got to figure out what the cost of it all getting it legit.. ill give an engineer a call.
ie cost of emissions, engineer, manifold shields, air boxes
-Engineer Cert?
-Emissions test?
-All the above?
